Reliable CD Player for ~$300
0 Members and 1 Guest are viewing this topic. Read 4845 times.
john1970
« on: 18 Feb 2007, 03:02 pm »
Dear AC Members,
My NAD 502 CD Player is on its last leg (it is starting to mistrack on the end of ALL CDs) and I am looking for a new player in the $300 +- 20% price range.
My short list includes:
1) Marantz CD5001 Single Disc CD Player 3 yr warranty List: $329.00
2) Sony ES 5 Disc SA-CD/CD Changer SCD-C2000ES 5 yr warranty List: $399.00 (sells for $299 and J and R).
3) Cambridge Audio Azur 340C 2 yr warrany List: $329.00
I am leaning towards the Sony ES 5 disc changeer because it has the best warranty and I can get it for 25% off of retail from an authorized on-line dealer.  Any suggestions are welcomed.
Thank you,
John
avta
Re: Reliable CD Player for ~$300
« Reply #1 on: 18 Feb 2007, 03:49 pm »
Oppo players have gotten some excellent reviews and you can't beat the price.
rosconey
« Reply #2 on: 18 Feb 2007, 04:52 pm »
might try a toshiba dvd-the new one sounds better they say than the 3950 -and put the 250$ you save in the bank
lcrim
« Reply #3 on: 18 Feb 2007, 05:07 pm »
If I had $300 to spend on CD playback I would get a Squeeze Box 3.  You couldn't post here if you didn't have a PC so you're set.  Pick up a X-over cable if you don't have a home network, maybe $10.  Download Exact Audio Copy, its free and Slim Server also free.  Never worry about a CDP breaking down again.
fredgarvin
« Reply #4 on: 18 Feb 2007, 05:10 pm »
I can vouch for the Marantz cd5000 but have not heard the 5001. I would rate it much better than the Toshiba's I have owned. I prefered it's own dacs over a couple of outboard dac's I tried as well. If you are using an outboard dac, I suppose it broadens your choices. The Cambridge gets a lot of raves as well.
Wayner
« Reply #5 on: 18 Feb 2007, 10:25 pm »
I have the CD-5400 by Marantz and it's a great player. The newer version CD-5001 has newer D/A chip set and I'm sure will sound great. The drawer is fast, the headphone amp (with volume control) will blow your ears out and it has a remote.
W
tvad4
« Reply #6 on: 18 Feb 2007, 10:31 pm »
If you're buying new because you want the warranty coverage, then hopefully you've verified that Sony will honor the warranty of a unit purchased on-line through an unauthorized dealer. I don't know if this is Sony's policy, but I know it's Denon's policy. I also don't know J&R's dealer status with Sony.
If you might consider a used player, then a used Sony DVP-7700 ES would be excellent for around $250. Later you could add a DAC and have a top drawer digital front end.
BTW, I have a Sony ES CD changer that I purchased new in 1992, and it's still running like a Swiss watch. Never has required servicing.
« Last Edit: 18 Feb 2007, 11:24 pm by tvad4 »
WEEZ
« Reply #7 on: 18 Feb 2007, 10:54 pm »
Of the (3) mentioned, my vote would be for the Marantz.
SET Man
« Reply #8 on: 19 Feb 2007, 01:24 am »
Hey!
  I own Sony 5 discs SACD/CD changer SCD-C2000ES since it first came out. I picked it up from J&R. It had been a while now but it still work flawlessly.
  The sound is pretty good. Actually better than I expected by itself. But now I'm using it as a transport feeding my DAC kit and the sound is better. The Sony work well as a transport. And of cause it is very convience to have 5 discs ready at your finger tip :wink:
   BTW... the previous CDP I had was '93-94' Rotel bottom of the line model single disc CDP. I have have it in my second/TV system but it is starting to give out I think :?
Take care,
Buddy :thumb:
Soundbitten
« Reply #9 on: 19 Feb 2007, 02:41 pm »
I replaced my aging Adcom700 with Sony ES 5 Disc SA-CD/CD Changer SCD-C2000ES last year . I use it with a tube dac but it sounds great alone too .
Folsom
« Reply #10 on: 19 Feb 2007, 08:18 pm »
S Clark
  • Guest
« Reply #11 on: 20 Feb 2007, 04:27 am »
Another vote for the Marantz 5400 model or newer
TheChairGuy
« Reply #12 on: 20 Feb 2007, 06:02 am »
Whatever you can find for <$200 and a $99.00 Dakiom Feedback Stabilizer.
eric the red
« Reply #13 on: 20 Feb 2007, 06:43 am »
I'd get a $300.00 TT instead :weights: :banana piano:
Wind Chaser
« Reply #14 on: 20 Feb 2007, 04:01 pm »
If only a TT could play all the latest greatest music...
Oh, and add another vote for the Marantz.  Pretty much all CDP's are reliable so I wouldn't be too concerned about warranty.  If you're not to picky about the sound of the unit, then a CDC (Changer) would be great for the added convenience.
Soundbitten
« Reply #15 on: 20 Feb 2007, 08:46 pm »
Is that right ? A single disc player will beat a changer in all instances ?
Wind Chaser
« Reply #16 on: 20 Feb 2007, 08:59 pm »
Soundbitten,
You're reading too much into my post.  In the context of the 3 stated options, the single disc Marantz player is musically a better option than the Sony changer.
Soundbitten
« Reply #17 on: 20 Feb 2007, 09:03 pm »
Soundbitten,
Sorry , I misunderstood your post . Thanks for the clarification .
Wind Chaser
« Reply #18 on: 20 Feb 2007, 09:08 pm »
No problem  :beer:
navi
« Reply #19 on: 21 Feb 2007, 07:26 am »
I would  recommend you try out a few of those chinese DACs and CD player.
