Budget preamp advice needed
0 Members and 1 Guest are viewing this topic. Read 1831 times.
fileundernewby
« on: 17 Feb 2007, 02:55 pm »
Hi there,
I'm slowly building my system and need to address the weakest link -- the preamp.
I am using the preamp out plugs from an old Luxman R-113 receiver to route my DAC to a Bryston 2B-LP and then out to Paradigm Studio 20s.
I'm not happy with the Luxman and would like to buy a starter separate preamp.
However, my budget is very limited at the moment so I'm hoping for recommendations for cheap preamps. I'm currently considering something in the range ($150-$300) of a used Rotel or NAD preamp or preamp/tuner. Have also looked at a dedicated volume control (Goldpoint, Axiom) but don't think I'm ready at this stage to give away the possibility of tone controls.
Anyway, I'm clearly a newby and was hoping that perhaps some of you long-term Bryston owners could suggest a temporary, inexpensive preamp that would pair well with the Bryston.
WEEZ
Re: Budget preamp advice needed
« Reply #1 on: 17 Feb 2007, 03:42 pm »
Welcome to Audio Circle.
(you have a pm)
WEEZ
john1970
« Reply #2 on: 23 Feb 2007, 11:46 pm »
FYI,
I have a Bryston 4B SST and am using the preamp section from a NAD C372 integrated amp.  While it is not quite as good as a dedicated preamp (such as a BP26).  The NAD delivers 95+% the performance of the BP26.  I A/B both the BP26 and NAD C372 through a Bryston 4B SST at a friend's and could just barely hear a difference (and a difference does NOT imply an improvement, just a difference).  A NAD or used Adcom preamp is probably a good choice.
The speakers were VMPS RM/X with TRT caps and Bolder Sliver Wiring throughout (~$15K /pair retail).
Save your money,
John
« Last Edit: 24 Feb 2007, 11:41 am by john1970 »
nuhi
« Reply #3 on: 24 Feb 2007, 02:10 am »
Level of difference depends on speakers and cables used as well.
guest41324
  • Guest
« Reply #4 on: 25 Feb 2007, 06:45 am »
Hi there,
Use your computer and get a decent sound card; seriously
