0 Members and 1 Guest are viewing this topic. Read 5049 times.
I'm pretty sure bass is summed to mono below 50hz when the records are mastered. I think this is part of the RIAA equalization curve.
That's because you just put your speakers out of phase.
Bass itself is not stereo by it's nature. The long wavelengths that are required to produce bass tones really put any stereo effect into the null zone. That's why you can put a sub-woofer way off center in a surround system, 'cause it really doesn't matter. Yes. you have to fiddle around with finding the right spot, but when you do, even with the sub-woofer way to the left or right, you hear it coming from the center. Because of this, LP's are mono in the lowest fundamental frequencies. Even if the record companies didn't slope to mono after 50 hz, they would still sound "mono" with regards to the lowest frequencies.W
i posted the same question at the Vinyl Asylum and received the same responses....essentially the stylus would have a tough time with stereo bass under 50hz or so. this saves me some $, thanks so much guys! A related question: Does it matter which rca output the mono sub cable is connected to? Left or Right channel?? i've had it connected to the Left - just curious.
Quote from: gooberdude on 8 Feb 2007, 08:24 pmi posted the same question at the Vinyl Asylum and received the same responses....essentially the stylus would have a tough time with stereo bass under 50hz or so. this saves me some $, thanks so much guys! A related question: Does it matter which rca output the mono sub cable is connected to? Left or Right channel?? i've had it connected to the Left - just curious.goober, you're making a big mistake going w/only one sub, imo. stereo subs will improve *everything* about your sound. soundstaging, smooth bass response, tighter, more accurate, less distorted bass, better room loading, you name it.
