0 Members and 1 Guest are viewing this topic. Read 6685 times.
Will the V60s come in the same (or a similar) range of finishes as compared to the RM40?
By the way, I've been intrigued by open baffle speakers for a while now. I think the V60s provide a neat solution -- a mixture of RM40-like huge "wall" of midrange/highs, great looks and bass control where I think it's better placed, which in a sub you can put in locations to reduce room anomalies. The only detriments are (obviously) cost and also independent bass module. I think it's simply harder, in terms of work the user has to do, to get an independent bass module to blend in seamless with the main speakers. On the other hand, you get to place the module where it interacts less with the room. The ability to notch out a peak is also a great idea.
Based on my experience with the STIIISRE in my soundroom, there is no doubt in my mind that a pair of the VLA woofer towers provide the best possible bass loading for a room that size. There is a large difference between a pair of very good subs like the VSS and a pair of VLA, mostly in how the room is energized. The effect is akin to the spread of a symphony orchestra across a stage, even if most bass is coming from a single area.
Quote from: Brian Cheney on 9 Feb 2007, 01:50 amBased on my experience with the STIIISRE in my soundroom, there is no doubt in my mind that a pair of the VLA woofer towers provide the best possible bass loading for a room that size. There is a large difference between a pair of very good subs like the VSS and a pair of VLA, mostly in how the room is energized. The effect is akin to the spread of a symphony orchestra across a stage, even if most bass is coming from a single area.Obviously true. However if one is forced to compromise and choose between one VLA or two VSS subs which is the better choice?
