I, for one, am most interested in the BlackGate upgrade(s). Unfortuneately, just saying upgrade to BlackGates is less than specific; which kind (N,C,VK,FK,PK, Standard???) what voltage ratings. capacitance values..... in which positions? The differing types of Blackgates have distinct impact, depending on their use. Their 'generous' voltage ratings require an 80% voltage use, max. So upgrading the 5 appropriate (not touching the rail main caps or the bootstrap cap) caps will cost $100/channel for the primo N series, and $50/channel for a cheapskate's mix of FK, C, and a single N. So we're talking $100 or $200 here for a stereo amp. Depending on one's metrics, this might well be an extremly cost effective upgrade. I've never heard anyone denigrate the BGs on this cirle, nor has Hugh on his website.
I would encourage you to share your expertise, but you've not yet shared any information to date. Inquiring minds want to know!
While Hugh offers the Nirvana upgrades, please realize he is trying to earn a lliving, and simply cannot market that which has little probability of supplementing his profits. Unfortuneately, this motly lot here is quite price sensitive. Please realize that vendors such as Steve McCormack charge thousands for their BG upgrades. Nothing stops the end user from buying their own Blackgates -
http://www.referenceaudiomods.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=RAM&Category_Code=BG_Nor at Partsconexion.com
and we would all appreciate specific input. Have you or anyone else evaluated the Nichicon KGs?
Any part upgrade, or architectural change, whether in the signal chain or power supply, must be evaluated not only for its absolute benefit, but in comparison to its next best and cheaper competitor. If our metrics were straightforward, and individual changes were orthogonal, optimizing performance for cost would simply be solving a system as a lp problem. But they aren't , they aren't, and it isn't.....
Hugh -
Unfortuneately, the Rubycon ZAs are only available in a 35v max rating constraing their use to the ltp decoupling, the feedback shunt, and possibly the Vbe bypass, not the main rail(s) decoupling.... And the only place I knew of their availability, Pioneer Electronics, is no more. And even there, they required a 16week leadtime special order in quantities of 1-2k/value. I also hear that Australia's switchmode PS industry isn't that large.
