Motorized disc cleaner?
0 Members and 1 Guest are viewing this topic. Read 2868 times.
KCI-JohnP
« on: 18 Jan 2007, 11:48 pm »
I know I know, I'm being lazy.... but I've been looking for one and can't seem to find a good one with out taking out a second mortage! Does anyone use these or have an links they can point me towards? Thanks for the help.
Sincerely,
John
KCI-JohnP
Re: Motorized disc cleaner?
« Reply #2 on: 19 Jan 2007, 02:05 pm »
Hi Scott,
Thanks for the links. I had found those two but seems they don't clean cd's as they should, they clean them in a circular motion. Thanks again!
J
Levi
« Reply #3 on: 19 Jan 2007, 02:10 pm »
I am currently using an ultrasonic device that is also used to clean jewelry.  So far so good.
KCI-JohnP
« Reply #4 on: 19 Jan 2007, 04:42 pm »
Hey that's a good idea, shoot man I think they even sell those in Wally world and Target! Thanks Levi.
John
Levi
« Reply #5 on: 19 Jan 2007, 04:46 pm »
You are welcome.
I bought mine at Bed Bath and Beyond.
PhilNYC
« Reply #6 on: 19 Jan 2007, 04:50 pm »
Levi...you wear jewelry?  :wink:
gooberdude
« Reply #7 on: 19 Jan 2007, 04:57 pm »
Be careful with any motorized cleaner...if even tiny bits of dirt get on the cleaning pads they can
grind into the optical surface and leave scratches.  The machine's work great until the pads get soiled...i've used the one that can be purchased at Rat Shack.
The technique I use seems to do well, though its not automatic by any means:
First, rinse the CD with water, whether its a blank or redbook or DVD or whatever.  I always use Viva papertowels, they are clothlike, leave no lint whatsoever and have a grip like no other. the wagon wheel technique for drying is used (from center outwards).  I'm convinced CD's and DVD's are sealed and waterproof - the ultrasonic cleaner sounds cool!
After the rinsing, i apply Mikrosmooth to the CD and apply with a clean and wet applicator pad (comes with the product).  The key with this is to wet the towel before every disc and shake off the excess water before aplying Mikrosmooth...no scratches occur on the surface and it makes the process go a bit faster.
Aside from cleaning discs really well, it removes the sharp edges & pits on the optical surface that leads to scratches.  EX: my car cd player always scratches CD's after a while.   The CD's don't get scratched if I've cleaned them with MS.
After rubbing in the MS for a minute, i rinse again and wipe dry with a Viva paper towel.
Sonic improvements aside, this technique makes discs more friendly to deal with...they slide all over the place since there's no friction on any of the surfaces and its difficult to scratch them.
this technique was developed to clean up crunchy Netflix DVD's...
Levi
« Reply #8 on: 19 Jan 2007, 05:00 pm »
:lol: Bwa ha ha ha.  No I don't.  I don't even like to wear my wedding band.  Definitely it has the WAF and you can clean all sorts of small items.
Levi
« Reply #9 on: 19 Jan 2007, 05:02 pm »
There is nothing better than the good old fashioned way.
