0 Members and 1 Guest are viewing this topic. Read 5008 times.
I have just ordered Kit #1 from Rythmik Audio. http://www.rythmikaudio.com/servo_product.htmI will be using BBB grade baltic birch for the cabinet, in a double-box configuration. I will then add a set of vibebuster8 spikes from RawAcoustics, along with the Ice Acoustic foam. I will keep folks posed as I build this.
I just put the baffle on my box and am just letting glue dry. Did the whole thing today. That's fast for this guy. I can build walls but doing furniture grade cabinet work isn't something I'm used to doing. I'm going to rebuild my first sub so it's a bit smaller and much nicer looking. Tomorrow I'll put on stain and several coats of varnish. I may even try to round corner the front baffle. I'm not used to using a router. I probably have a half an hour of experience total now. I went with the PE 500 watt plate amp. I have a Rythmik but thought the extra power as well as having another band of parametric equalization would be worth a few bucks more. Besides they're on sale. The driver I'm using is the Dayton RS HiFi 15" in sealed cabinets.If you know of a wood filler that doesn't shrink I'd appreciate it. I have two kinds, both say they don't shrink, both do. Thanks
So, you didn't go for the servo option? From my understanding of what you wrote, you are using the PE500 and the Dayton RS HiFi 15 in you rcurrent project. Am I correct? Did you play with the Rythmik amp much?I will be very interested to hear your thoughts on any comparison you can give. The main attraction for me with rythmik is that the amps and drivers are specifically tailored for each other to produce a combined effect. Do you see much of a difference in build quality between the two amps?Good Luck! -AF
Well it's been this evening for a few days now Where's our pics?
