Rythmik Servo Sub on order!
0 Members and 1 Guest are viewing this topic. Read 5041 times.
DSK
Re: Rythmik Servo Sub on order!
« Reply #20 on: 25 Jan 2007, 01:42 am »
IIRC Brian recommended 2" thick polyfill on all walls. So, that is what I did and I'm very happy with it.
RAW
« Reply #21 on: 25 Jan 2007, 02:48 am »
With your RAW ICE lining the cabinet walls ,I would just add a small 12oz bag of poly you can get from Wal-Mart and you will be set.
All the best Will
audioferret
« Reply #22 on: 25 Jan 2007, 08:11 am »
I will add more pictures as soon as I get a chance.  I will need to open it up to show you the insides.  The Ice Dampening Foam completely lines the inside.  Very nice stuff and easy to use.  I have enough left for a few future projects...
The wife was totally surprised by the 30Hz heartbeat at the beginning of Pink Floyd's DSOTM, along with the bass in a number of other tracks.  So far, this is sounding really good.  The Vibebuster 8 spikes have not arrived yet, but I hope they come in by this weekend.    :(
This is the best bass I have heard in my theater, bar none - even before calibration.  I should have it calibrated with RDES by this weekend.
« Last Edit: 25 Jan 2007, 10:51 pm by audioferret »
audioferret
« Reply #23 on: 27 Jan 2007, 10:06 pm »
I have just finished building a Rythmik Audio Servo Subwoofer Kit #1 from Rythmik Audio.  The sub can be found here at www.rythmikaudio.com.
Let's just say I am impressed.  I am currently in step three of bossobass's setup guide.
Mains, pretty much the same as before.
Subwoofer.
And the current combined plot.  NOTE:  I have applied absolutely NO EQ.  This is just done after the level-matching stage of Bossobass's setup guide.
audioferret
« Reply #24 on: 27 Jan 2007, 10:07 pm »
Now adding +10 at 70 Hz using my receiver's tone controls...
and easing off the subwoofer a little bit....
warnerwh
« Reply #25 on: 30 Jan 2007, 09:13 am »
I do want to hear what you think of the sound quality now that you've owned it and used it for a few days. Plus it should be breaking in somewhat by now.
The RDES unit is a very nice little device.  It's easy to use and effective. Let me know what you think of the before and after difference please. Thanks
