Gallo sub amp..any probems? better bass?
0 Members and 1 Guest are viewing this topic. Read 1357 times.
megawatt
« on: 4 Jan 2007, 03:01 am »
Has anyone tried to use added subs with the Galllo sub?
« Last Edit: 8 Jan 2007, 03:58 pm by megawatt »
SET Man
Re: Gallo sub amp..any probems?
« Reply #1 on: 4 Jan 2007, 05:03 am »
Hey!
    Hmmm.... I don't own or have experience the Gallo and I'm not sure if I understand your problem. But let's see...
    So, you are hearing sound coming out of your mid while the sub amp is on alone while the main amp is off right?
     Okay, if my memory served me right I've read a bit about the Gallo 3 speaker and that the speaker is not bi-wire able but with the woofer on those speaker have a second voice coil that suppose to be connected to the sub amp via a second set of biding post.  I assumed that this is what you have.
    With that I think what you are hearing coming from the mid is really a signal from the first voice coil that is generated by the movement of the second voice coil that is connected to the sub amp. This is very simple to demonstrate. If you have two speaker and you connected them together + to + and - to - of each other... when you move one speaker the other will move too. :D
    So, I think this is why you are hearing the sound coming from the mids.
    As for the main amp blowing up the channel.... I'm not sure if this is the cause. But it is possible that the sub amp is feeding back the signal to the main amp. Not sure :scratch: But I could tell you that what Gallo use is a very strange way of connecting the sub amp of which I've never seen before. I don't know any other speaker that have this sub connection scheme... but I could be wrong. :D
     Anyway, hope this help... and maybe someone here with more technical background could fill in on this... well because I could be wrong on this :D
Take care,
Buddy :thumb:
carusoracer
« Reply #2 on: 4 Jan 2007, 02:31 pm »
I have had the SA for my ref 3's since the Amp came out. I have yet to have any problems with it other than the annoying fan noise.(A better design would help there or heat sinks) But I digress.
The only sound I hear on mine is coming from the 10" Driver. I do not hear any other noises from the other drivers. I would try and talk to Gallo directly. The Tech rep, I forget his name is very helpful and responsive if not available. The above post is correct, maybe check the wiring again of the two separate sets of speaker cables with the wiring diagram in the instructions. I know it sounds basic but you should not hear anything else emanating from the other drivers. Also check you volume control setting levels.
Good luck
megawatt
« Reply #3 on: 8 Jan 2007, 03:47 pm »
An electronic engineer told me it can be some tubes from my pre-amp failing and not the sub amp. I tried a passive preamp and nothing..no sounds at all. hmm?  i was told  an active pre can leak dc and you wouldn't be able to hear it and leaking dc can cause this too happen. It can also send yr amp into protection mode and some circuts don't have no protection can blow out yr output resisters...So I think   my problem is resovled
megawatt
« Reply #4 on: 8 Jan 2007, 03:49 pm »
Thank you guys for trying
