0 Members and 1 Guest are viewing this topic. Read 7656 times.
I built my sub using the Rythmik DirectServo kit in a sealed 2.0cu.ft. box with 1.5" MDF walls (box in box), full shelf braces supporting all panels, etc. It weighs 93lbs (42kg) so I won't be moving it anytime soon.
Quote from: DSK on 2 Jan 2007, 12:31 amI built my sub using the Rythmik DirectServo kit in a sealed 2.0cu.ft. box with 1.5" MDF walls (box in box), full shelf braces supporting all panels, etc. It weighs 93lbs (42kg) so I won't be moving it anytime soon. 1. On the Box-In-box design, did you build the interior box completely first before adding the second layer? or, did you work them both at once? How did you work the cutouts through the layers?2. For your shelf braces, did you orient on all three axis? How did you lay them out?3. Any advice for a new builder? I have built speakers, just not a sub. What would you do differently if you did it again?-AF
After doing extensive research I think the Rythmik servo sub is OVERATED Marketing Hype.
After doing extensive research I think the Rythmik servo sub is OVERATED Marketing Hype. Matt
When you say "flat" what do you mean? I have ETF data of my room, and my room's response is nowhere near "flat" even with 6 "bass" traps and 5 additional traps. Do mean that there is significant output at frequencies between 16-X Hertz or do you really mean that the output has no room-related frequency anomalies? If so, does this bass driver also use DSP techniques?
Thanks DSK, I am getting ready to order this kit. I have researched many different kits and I think this provides the most flexibility and performance for the price. I don't think that the Rythmik site is in any way deceptive - In fact I think he provides good information about the technology and It sounds quite promising. Have you considered using an EQ like AV123's RDES? I am using it with my current 150W 10" sub and the results are incredible. There was a really noticeable improvement in Bass quality. With the ability to quickly bypass your settings, the difference is easy to demonstrate. Does anyone have a better kit to recommend for less than $500?
achieve lower extension and flatter response in a small enclosure - from the Rythmik website
Quoteachieve lower extension and flatter response in a small enclosure - from the Rythmik websiteHow in the world would a servo sub help achieve lower extension and flatter response in a small enclosure?The only way I could possibly imagine it would be through the use of the Linkwitz Transform to boost the bottom end and then the servo to keep the woofer in check. How does this help the flatter response??I can buy this but how would this be better than using a high quality driver in ported box or PR box with a low F3 point?Being that Rythmik combo needs a 2.1 cubic foot box. This is not a smaller enclosure!! There are many subs that work with PR in the same sized box??I must really be missing something here. And how is the Rythmic patented? High Gain Servo™ Technology Patent by Velodyne in 1984???Matt
How in the world would a servo sub help achieve lower extension and flatter response in a small enclosure?... How does this help the flatter response??....how would this be better than using a high quality driver in ported box or PR box with a low F3 point?
With the current breed of super woofers exceeding 2.5 inches of travel the need for a servo controlled woofer becomes questionable at best.
Check out the audio control epicenter! How low do you want to go??
