0 Members and 1 Guest are viewing this topic. Read 12293 times.
I know getting takers in your area will be tough, so I will gladly try it out for you.
Right now this particular cable is ONE prototype version of what will eventually be offered as NAPALM.I do have some other ideas, but I do neeed to build a few cables first to actually listen to them. All the theories and tests don't mean a thing if the cable doesn't sound any better in actual use in a system playing music.
Bubba, you will get a beta version of the cable to play with. Your constant prodding me on finally convinced me to build this design.
I am going to play with the look of the cable as well as the materials it is made from.
I am not sure when the next Cryo run will be but I am sure there will be a Napalm prototype in it.
My bullet-plugged Bolder digital is going to be leaving my system in a week to make way for......
