0 Members and 1 Guest are viewing this topic. Read 7674 times.
if one is going to introduce more than one new component, how do you all do it? One at a time just so you can hear what the new component is doing? How long before introducing the second new component?
Keep a close eye on the weakest link, which for me has always been speakers. I can switch 10 amps in and out of my system or 10 preamps or change my CDP but nothing makes a difference like speakers. Everyone here has different views but IMO it's important to focus on finding speakers I like and then fine tune my system with wires, amp swps, etc.... I personally hear no difference b/t balanced and unbalanced in my system.
Don't get hung up on balanced connections/cables
I agree with this advice 100%. Chose your speakers first as everything else you do refines the sound produced from the speakers. Also, the efficiency ratings of your speakers will dictate the size amp required to properly drive them. Seriously consider the used equipment/dealer demo markets and save yourself a lot of money. Most of the time there is nothing wrong with the equipment, it is just a case of upgrade itch! When I started this hobby several months ago Lonewolfny gave me the same advice he gave you, "Take your time."
As mentioned above, the pre-amp can be the piece needed to flavor your sound. Once we've got a handle on what audio attributes you're after we can make suggestions.
