0 Members and 1 Guest are viewing this topic. Read 7670 times.
We need to know your constaints (room size, wife acceptace factors, budget, can you DIY, etc.)
To answer the question... no, I wouldn't bother about balanced connections.
Here's another piece of advice, worth probably exactly what you paid for it--quit worrying the details and pay attention to the big things.I feel loudspeakers are the most-important component in your system, so pick them first. That choice will create power requirements, etc. So start at the end and work back.
I did start with the speakers, PBN Montana XPs
Quote from: JohnR on 27 Dec 2006, 09:20 amTo answer the question... no, I wouldn't bother about balanced connections.Why? Let's say for a moment that I initially begin to select components based on how well it sounds without regard to whether they have balanced connections or not. At some point, though, I might add a component that has both. Now I am faced with a system that has incompatible (?) equipment.
That takes care of my first question and could be a perfect segue into another question, integrated or separates?
The questions.1. Selecting system components and system matching, how much consideration should one give to choosing an amp and pre-amp that have both balanced and unbalanced connections? I have read that balanced can sound better but I am sure that one cannot assume that a balanced system will necessarily sound better.Still, I am starting with an almost clean sheet of paper, and while I will try and audition several types of equipment where I can to see what sounds best to me given my speaker choice and room acoustics, I'd like to know if YOU could start completely over again, would you give any weight at all to whether or not the amp/pre-amp had any balanced connections? I will want to at least try tubes somewhere in the system, if that makes a difference.Thanks,--Michael
Those RCA's are line level. You should be able to hook the new amp just like the Pioneer.What kind of new amp do you have?
