Stratos Monos Burn in time
0 Members and 1 Guest are viewing this topic. Read 1793 times.
martinr
« on: 19 Dec 2006, 01:44 am »
I got my system yesterday - stratos monos extreme, candela and loreleis - Klaus told me it would take about 3 months for the system to fully burn in - what are your experiences with the Stratos Burn in time?  Is the change in sound that drastic once burn in is complete?
Martin
LightFire
Re: Stratos Monos Burn in time
« Reply #1 on: 19 Dec 2006, 07:25 am »
There is no need for burn in. Don't waste your equipment's life. You may think things are getting better, but it is all in your mind. Placebo effect.
Wizard454
« Reply #2 on: 19 Dec 2006, 07:29 am »
Martin,
I have had my mono extremes for a little over 5 months now the change is a gradual one. They start off sounding lean and over time you just seem to say "wow" that's starting to sound really, really good. And yes I would tend to agree with the 3 month break-in estimate even after that they still seem to  keep evolving to some degree. Although that just might be me as I do travel a fair bit on business and coming home after a week or two on the road the system sounds better than it did before I left.
One tip "leave them on" it does take 2~3 days for them to charge back up again if you turn them off (seems silly I know but it's true).
Good luck and good listening you're going to really enjoy your mono's!
Fred
djbnh
« Reply #3 on: 19 Dec 2006, 10:56 am »
I almost continuously used a dual-well cassette deck, as well as intermittent normal CD and vinyl use, to give my Extreme Monos about 400 hours of continuous playing time for burn-in. I note I leave my Extreme monos on full time, per Klaus' directions.
FYI - Klaus' web site talks about the break-in process for Odyssey solid state gear.
carusoracer
« Reply #4 on: 19 Dec 2006, 02:45 pm »
Martin
See my post in the Odyssey forum thread regarding burn in time....3 months powered on and 400 hrs playing was about right
lazydays
« Reply #5 on: 19 Dec 2006, 05:27 pm »
Martin
three hundred hours minimum. Mine took about three hundred fifty to three seventy-five hours playing 24/7. Or pretty much a solid month of extended playing time. I drove mine during breakin with a B&K tuner preamp feeding into a pair of Polk 800 series speakers out of my HT system. Funny thing about those Polk speakers was that I just never really liked them for music, but they had a comppletely different sound with the monos driving them.
gary
