velodyne dd10
0 Members and 1 Guest are viewing this topic. Read 1116 times.
norman
velodyne dd10
« on: 14 Dec 2006, 10:13 pm »
is the dd10 and the dd series reliable
i know there are problems with the spl   r    series
thanks    norman
cmach
Re: velodyne dd10
« Reply #1 on: 14 Dec 2006, 10:35 pm »
I have had a DD-10 for a couple of years now. Its a fine sub if your room is on the small
side. I have had no problems with mine. Velodyne has great support so you should have
no worries.
Cmach
ZooDog
Re: velodyne dd10
« Reply #2 on: 16 Dec 2006, 07:36 pm »
Yes, but I would also check out the new offerings from JL Audio.  They are supposedly superior to the DD series.
