Help Recomend a new pair of speakers
0 Members and 1 Guest are viewing this topic. Read 2857 times.
Antman27
« on: 14 Dec 2006, 08:17 pm »
Hello all ,well it looks like in early 07 I should be able to swing a new pair of speakers. I am looking for Large bookshelf speakers and can only be 9" wide ( due to the furniture they will live on) the furniture is about 20 " high and my sofa is on the taller side so a speaker about 20" tall Give or take would be great.
I will also want to use the speakers for HT so something with matching center would be great.
I know most bookshelf speakers don't go that low but I want something that could be called full range and can get down low. (my speakers now are rated to 36Hz but dont come close to that more like 60Hz)
Light wood would be great also .I will be driving them with a Denon 3805 AVR and will add an amp for 2 ch listening in the future.
I listen to Electric Blues/Jazz / Rock
Budget $1500 give or take
Thanks for your thoughts
Zero
Re: Help Recomend a new pair of speakers
« Reply #1 on: 14 Dec 2006, 09:39 pm »
The ACI Sapphire XL seems to fit the bill perfectly...
Hogg
« Reply #2 on: 15 Dec 2006, 01:58 am »
The BESL 5MT may meet your needs.
http://www.bamberglab.com/s5mt.shtml
        Jim
Canyoneagle
« Reply #3 on: 15 Dec 2006, 03:07 am »
You might also check out Canton
I've owned several of their Ergo series, which I can say are spectacularly built and sound excellent.  The top bookshelf Ergo is the 603.
http://www.canton.de/en-produktdata-ergo-ergo603.htm
I'm not familiar with their other products, but they seem to get good press (primarily in Europe)
.....also try Totem Acoustics
http://www.totemacoustic.com/
Good luck!
Michael
« Reply #4 on: 15 Dec 2006, 10:32 am »
VMPS 626
Scott F.
« Reply #5 on: 15 Dec 2006, 12:31 pm »
The Odyssey Epiphany's would do a bang up job plus they are less than half your budget.
bpape
    • Sensible Sound Solutions
« Reply #6 on: 15 Dec 2006, 12:40 pm »
I'll second the ACI's.  It's almost as if you were looking at them when you were describing what you needed.  They're a slight stretch on the budget but not much - and they're solid down to the low 40's.  The only thing is that they definitely need an amp behind them - not a bad thing just something to consider.
Bryan
tvyankee
« Reply #7 on: 15 Dec 2006, 03:36 pm »
VR'1s
you can get all the matching speakers you want and you can get great prices on the net.
http://www.vonschweikert.com/zvr1.htm
http://www.vonschweikert.com/zlcr15.htm
http://www.vonschweikert.com/zvrs1.htm
http://www.vonschweikert.com/zts150.htm
Hope this helps
gitarretyp
« Reply #8 on: 15 Dec 2006, 03:51 pm »
How about the Selah SSR or RC3R? Both meet your size, price, and response desires.
woodsyi
« Reply #9 on: 15 Dec 2006, 04:11 pm »
VMPS 626
Did I see 626R? :D I have a light oak pair in great condition with mega woof, FST and stock (Solen?)cap for well under your budget.  The baffle, however, is 10.25" wide.
PhilNYC
« Reply #10 on: 15 Dec 2006, 04:29 pm »
I'd consider the following:
- Green Mountain Audio Europa or Europa Max (retail slightly below your pricepoint)
- Aurum Cantus V2M  (retail exactly your pricepoint)
- Focus Audio FS-68SE (retail slightly above your pricepoint)
Canyoneagle
« Reply #11 on: 18 Dec 2006, 12:47 am »
Here's a nice pair of Canton Ergos on the 'gon for $550 obo ($1300 retail).....
http://cls.audiogon.com/cgi-bin/cls.pl?spkrmoni&1169229060
There are many excellent choices out there in your price range (as the responses have shown).  Have fun!
Warmly,
Michael
