0 Members and 1 Guest are viewing this topic. Read 30732 times.
I've done a comparison using a linear PS I purchased and didn't hear any difference
I did that and I heard differences.
Which linear PS and components did you use for the test??
That blind enough, opaque, or do I need to make an investment at my local S&M shop?
Well.... for me, not really.
The problem is things like that do tend to happen by accident sometimes, especially since she knew you were buying it -
and we only remember the times these things happen and not when they don't, so there's a pretty powerful selection bias.
But look - this is all just purely personal, just to satisfy my own skeptical nature (which I'll admit is pretty strong ), so feel free to ignore it!
Anyway, I didn't mean to start a big discussion here, but if anyone has or knows of a positive result in a controlled test I'd love to hear it!
the sonic differences between the stock sb ps vs a good linear ps is pretty blatant in both analog/digital out. (assuming you have decent gear of course) you don't need to do blind tests to hear the differences.
1) in the directions it says something about soldering the heat sink to the PC board. Is there something I'm missing or do I need to go out and get a heliarc welder to deal with the aluminum heat sink? Maybe the locator studs are plated with something? Or, maybe this is just confusing language in the manual?2) I assume the hot lead of the AC input is going to the hole on the PCB nearest the fuse?Ah, one more thing came to mind, on the Elna caps, which polarity is the short lead? I have pretty much everything else marked and identified with regard to polarity, just forgot the orientation of the big caps.Thanks for any help,Jim
