DIY Turntable
0 Members and 1 Guest are viewing this topic. Read 2599 times.
PaulHilgeman
DIY Turntable
« on: 1 Dec 2006, 11:16 pm »
Some interesting pictures of something I have been working on with scrap wood and scrap time.
Paul
JoshK
Re: DIY Turntable
« Reply #1 on: 1 Dec 2006, 11:44 pm »
Cool!  What are you using for a motor?  I am assuming your platter is made of bamboo?  I'd love to try a bamboo platter, how did you spin it?
PaulHilgeman
Re: DIY Turntable
« Reply #2 on: 2 Dec 2006, 12:20 am »
Hey Josh,
The motor will be a PWM (35Khz) controlled DC motor.  I should hopefully be able to get it just perfect, I am going to have it set-up so that a single potentiometer can make EXTREMELY precise adjustments to the motor speed.  The controller and motor will be in a single box sitting off to the left side.
As you can see, I am still using an old arm from a TT that was give to me a few months ago, but honestly I dont even own a ton of vinyl, so this is just to get me started.  At least the table will be good (I think?!?!?!).
The platter was made with a router and a circle jig, then proceeding layers were sandwiched on and flush routed to match the perfect one.  It turns for a REALLY long time.  I need to decouple the table from the stand somehow, but I am not sure how yet.  Bumping the rack really makes some big bass :).
-Paul
JoshK
Re: DIY Turntable
« Reply #3 on: 2 Dec 2006, 12:28 am »
So you are going to use a direct drive system then I presume?  What are you using for bearing?
I am not the expert in DIY table construction, so I am not sure what would make a good decoupler.  It would depend on how you are driving the platter.
PaulHilgeman
Re: DIY Turntable
« Reply #4 on: 2 Dec 2006, 03:13 am »
belt drive
xsb7244
Re: DIY Turntable
« Reply #5 on: 3 Jan 2007, 04:01 am »
is your turntable project finished?  how does it sound?
PaulHilgeman
Re: DIY Turntable
« Reply #6 on: 3 Jan 2007, 04:06 am »
No,
Too busy building speakers!!!
Developing a Ronin with a built in woofer amplifier, developing the Sentinel and piano black glossing my pair.
I have the motor controller working though, I just need to build a housing for the motor and tweak away.
-Paul
Russell Dawkins
Re: DIY Turntable
« Reply #7 on: 3 Jan 2007, 07:26 am »
-Paul
My brother had good results suspending his turntable from two ceiling hooks with surgical rubber tubing. Bungee cords would be equivalent but less elegant, possibly.
