Clarity Cap SA Series
0 Members and 1 Guest are viewing this topic. Read 2361 times.
PaulHilgeman
« on: 30 Nov 2006, 06:56 pm »
Just noticed this over on TNT Audio:
http://www.tnt-audio.com/accessories/claritycap_e.html
It is about the SA series of capacitors which I use in the Ronin.  I went through quite a few caps, replacing everything in the circuit except the woofer shunt cap and found that I liked these the best after about 3 weeks of listening to each brand that I tested.  The review is correct though, they are VERY large.
Definitely a quality product.  My experience with them is only with speakers where they have worked very well.
Tony Gee liked them quite a bit in his cap comparisons although they seem less scientific.
Happy Reading!
Paul Hilgeman
Kevin Haskins
Re: Clarity Cap SA Series
« Reply #1 on: 30 Nov 2006, 07:12 pm »
You are right on.... the SAs are an awesome cap for a VERY reasonable price.
PaulHilgeman
« Reply #2 on: 30 Nov 2006, 07:55 pm »
Kevin, have you tried the DTAC's?
I got my samples and then just said "forget it".  If you had a 5" woofer, and a 15uF cap, you wouldn't be able to put the cap through the woofer hole, the thing is like a CD!!!
And M8 screw terminals????  Crazy
Kevin Haskins
« Reply #3 on: 30 Nov 2006, 07:59 pm »
The main problem is that you have to design a PCB around them to even give them an honest listen.    Even if they are superior, it wouldn't be a finanancially viable proposition due to the mounting difficulties.
So in short.... no I have not tried them although I use one as a paper weight on my desk.  ;-)
PaulHilgeman
« Reply #4 on: 30 Nov 2006, 09:43 pm »
Yes, they are awesome looking.
-Paul
