DEQ
0 Members and 1 Guest are viewing this topic. Read 3210 times.
EProvenzano
DEQ
« on: 13 Nov 2006, 06:58 pm »
Hello folks,
I'm curious to know if there is a mid-line alternative between the Behringer DEQ2496 at the lower end, and the Tact or DEQX at the higher end?
I'm intrigued by the Behringer, but I'm turned-off due to the poor quality reports that I read everywhere.
I'd like to use this equipment to begin playing around with room EQ, so the investment into Tact or DEQX is too great for me at the moment.
geofstro
    • Sound Galleries: High-End Audio in Monaco
Re: DEQ
« Reply #1 on: 15 Nov 2006, 08:38 am »
Have you considered a PC?
geoff
EProvenzano
Re: DEQ
« Reply #2 on: 15 Nov 2006, 12:31 pm »
Yes I have a PC for audio.  I'm currently using SB2 and Slim Server to stream my music to my stereo.
What did you have in mind?
geofstro
Re: DEQ
« Reply #3 on: 16 Nov 2006, 12:27 pm »
You may already be aware that with the right software you can perform DRC using your PC and apply digital XO's.
For DRC this is a good starting place:
http://www.duffroomcorrection.com/wiki/Main_Page
For Digital XO's check out:
http://www.thuneau.com
It works out well for me.
Hope it helps
Geoff
« Last Edit: 22 Nov 2006, 05:44 pm by geofstro »
playntheblues
  • D-Sonic, Mola Mola TamBagui, Tekton DISE
Re: DEQ
« Reply #4 on: 16 Nov 2006, 01:32 pm »
geofstro, those links aren't working :duh:
playntheblues
Re: DEQ
« Reply #5 on: 16 Nov 2006, 01:35 pm »
nevermind one to many W's   :lol:
ashok
Re: DEQ
« Reply #6 on: 16 Nov 2006, 03:46 pm »
http://wwww.thuneau.com
Geoff,
Which of the products at Thuneau.com are you using? Would it be the frequency allocator?
Ashok
dwc
Re: DEQ
« Reply #7 on: 16 Nov 2006, 11:37 pm »
BTW, you can run INGUZ's room correction plugin inside Slimserver - for free. (well you have to buy/borrow a mic and maybe a USB mic interface)
Head over to the slimdevices forums and search for "inguz".
I have not done it because I have a DEQ and run different rooms, but it is worth reading about.
EDIT: just realized Inguz is here, so you can ask him directly.
Norman Tracy
    • Audio Crafters Guild
Re: DEQ
« Reply #8 on: 17 Nov 2006, 01:12 am »
Noticed this in use at RMAF 2006:
http://www.dbxpro.com/4800/4800.htm
Looks like it $3700, ouch.
Maybe this:
http://www.dbxpro.com/12601261.htm
quick google shows street prices $1350
geofstro
Re: DEQ
« Reply #9 on: 22 Nov 2006, 05:43 pm »
playntheblues,
Sorry for late response and too many w's in the link. Yes Ashok, it is frequency allocator that I'm using.
geoff
« Last Edit: 23 Nov 2006, 11:22 am by geofstro »
EProvenzano
Re: DEQ
« Reply #10 on: 23 Nov 2006, 03:42 am »
Thanks for all the suggestions guys  :thumb:
The thuneau approach looks like it fits my current system very nicely, with minimal new equipment required.  It is a slightly higher learning curve than I have time for at the moment, but winter is looming...what the hell!
I'll do some reading on the Slim Devices forum and be sure to report back here if I delve into it.
Thanks again.
EP
DonnieW
Re: DEQ
« Reply #11 on: 27 Nov 2006, 10:58 am »
Hey for what it's worth I am extremely happy with my DEQ 2496.  Not only fantastic for room correction but also a great tool for RTA measurements (and more).  I regard it as one of the critical components of my setup and threfore money well spent.
