Caps and a Strat
0 Members and 1 Guest are viewing this topic. Read 1072 times.
pjchappy
Caps and a Strat
« on: 9 Nov 2006, 05:10 am »
Anyone have experience changing out the cap/caps in a Fender Stratocaster.  My Strat is modded a bit and has a total of 2 caps. . .one on each tone pot.  They are the standard caps that came w/ it and the value is .022uf.  Looking for what type of changes caps made for those who may be in the know.
Thanks in advance!
p
StevenACNJ
Re: Caps and a Strat
« Reply #1 on: 9 Nov 2006, 10:53 am »
I would shoot an email to the folks at Angela with your questions. They are experts:
http://www.angela.com/
pjchappy
« Reply #2 on: 9 Nov 2006, 08:02 pm »
Thanks!  I'm also hoping someone on here has experience modding a Strat. . .or another electric. . .and can comment on observed changes.
p
Daygloworange
  • www.customconcepts.ca
« Reply #3 on: 9 Nov 2006, 08:16 pm »
I've changed the volume pots on mine. I believe stock is a 250 Kohm, changed to 500kohm. ( I hope I got the order right, and values.
The difference from stock is the way the highs roll off as you turn down the volume. I believe that the mod doesn't roll of the highs as much. Some of my Strats have it, some don't. It's been years, so I don't remember.
I've always taken the tone controls out of the signal path, sorry I can't help you there. :guitar:
Cheers
pjchappy
« Reply #4 on: 9 Nov 2006, 08:23 pm »
Thanks.  I was looking more for changes made changing the quality of the components vs. the value.  I have a TBX tone control in mine and a push-pull knob for the other.  The TBX takes away bass in one direction, treble in the other, vs. just taking away treble for a normal tone pot.  The push-pull allows me, when pulled up, to control the volume of the neck pick-up and blend it w/ any other pickup (so, I can actually have all 3 pick-ups, or bridge/neck, which can't be done w/ normal 5-way switching). . .a pretty cool mod.
p
Daygloworange
« Reply #5 on: 9 Nov 2006, 08:35 pm »
The system you've got there, does sound cool.
Cheers
pjchappy
« Reply #6 on: 9 Nov 2006, 08:37 pm »
I dig it!   :D
You should whip out your Strat and make some changes!
Here are some mods, w/ wiring diagrams:  http://www.guitarelectronics.com/category/wiringresources.22pickupdiagrams/
p
Daygloworange
« Reply #7 on: 9 Nov 2006, 08:51 pm »
Thanks for the link.
Now I'd have to deal with yet another learning curve. Sheesh!  :roll:
Cheers
pjchappy
« Reply #8 on: 9 Nov 2006, 09:04 pm »
Oh, the mods are easy and playing w/ the new sounds is fun!  It's kinda like getting a new Strat!   8)
p
