Source for copper spade terminals? (any or no plating) (was ring term.)
0 Members and 1 Guest are viewing this topic. Read 1093 times.
James Romeyn
Changed from ring to spade terminals...Thanks all!
Looking for a good (read good price) copper-based spade terminals for 1/4" diameter studs & AWG 12 wire.  Larger AWG capacity is OK but no smaller than AWG 14.  Any plating including no plating is OK.  Did I say I like low prices?  (Need about 100.)
Vampire has them 4 prs $6.50, believe this includes heat shrink.  Insulators nice but not absolutely necessary.
Thanks much for your time.
Muhammad Al-Jimbolaya
« Last Edit: 31 Oct 2006, 02:54 am by RibbonSpeakers.net »
Steve Eddy
    • http://www.q-audio.com
Re: Source for copper ring terminals, any plating?
« Reply #1 on: 28 Oct 2006, 02:27 am »
Low prices? How's 31 cents each sound?
Mouser Part No. 571-33458
They're tin plated, but the base metal is copper, not brass.
se
James Romeyn
« Reply #2 on: 28 Oct 2006, 03:22 am »
se
You are de man!  Boy I love this forum.  Hey!  Why'd you take so long?  (30 mins)
Steve Eddy
« Reply #3 on: 28 Oct 2006, 04:04 am »
Sorry about that. Had to go bring peace to the Middle East and it took a bit longer than I anticipated.
Hey, nobody's perfect.  :green:
se
Scotty
Re: Source for copper ring terminals? (any or no plating)
« Reply #4 on: 29 Oct 2006, 03:53 am »
You could save the shipping and go to your local AutoZone or NAPA and buy
tin plated copper ring lugs. I think you can do better than 31 cents a piece.
Scotty
James Romeyn
« Reply #5 on: 30 Oct 2006, 09:13 pm »
Never would'a thought of that...many thanks!
OTL
« Reply #6 on: 31 Oct 2006, 12:02 am »
This should get you through....cheep!  Quan 50, 8ga for $11 bucks.  Several other options.
http://www.mcmaster.com/
Page 706
James Romeyn
« Reply #7 on: 31 Oct 2006, 02:55 am »
Scotty
Stores around here nickel only.
