What coils? (Modding a sonic T)
0 Members and 1 Guest are viewing this topic. Read 1518 times.
Reverie
    • My Myspace
« on: 25 Oct 2006, 12:32 pm »
Hey all,
I'm looking to replace the coils in my class T amp, but have been undecided as what to use.
I originally looked at air core ones like these: http://www.autocostruire.com/catalog/product_info.php?cPath=42&products_id=270&osCsid=e50147afd4248d799d250595868dcef8
But then, I noticed you stated the signiture 30 uses: 'Hand-wound toroid output filter inductors (favored over air-core inductors for better bass definition, speed, dynamics, and lower noise)', and considering the stunning review you got on 6moons, I'll follow your route :wink: 8).
What model are they? Ferrite cores I presume?
Thanks to all who can shed some light. :)
Vinnie R.
    • http://www.vinnierossi.com
Re: What coils? (Modding a sonic T)
« Reply #1 on: 25 Oct 2006, 01:49 pm »
Hi Reverie,
Welcome to Audiocircle.
I use hand-wound toroids that are custom made locally for me.
I moved your post over to the Lab because you might get some good DIY suggestions over here.  You might also want to post on www.diyaudio.com (Class D forum).
Best regards,
Vinnie
ohenry
« Reply #2 on: 25 Oct 2006, 02:06 pm »
Hey all,
I can send some, check your PM.
Reverie
    • My Myspace
« Reply #3 on: 26 Oct 2006, 12:44 pm »
Thanks Vinnie! I'll try looking where you suggested.
What material core do your toroids have may I ask?
Henry - now replying to your PM :D.
