Help, please
0 Members and 1 Guest are viewing this topic. Read 919 times.
Spirit
Help, please
« on: 24 Oct 2006, 03:02 am »
I have 2 new Odyssey Monos which I just turned on a few minutes ago.
Question:
My preamp's Main Output jacks provide a signal of inverted absolute phase.
If I don't reverse the connections on both speaker cables at the power amps or
the speakers can I do it by reversing the RCA's going from the preamp to the
power amps?  Will this maintain proper absolute phase?
I guess what I am also asking is - what is the proper way to connect this?
Appreciate the help please.
Brad
Re: Help, please
« Reply #1 on: 24 Oct 2006, 03:07 am »
Swapping the RCA's will just change the left-right channels.
You have to swap the + and - cables at the amp or speaker
warnerwh
Re: Help, please
« Reply #2 on: 24 Oct 2006, 03:33 am »
That's exactly correct above. However many recordings are done out of phase. So in effect either way you do it you're still not right alot of the time :o
