Tube Pre Amp
0 Members and 1 Guest are viewing this topic. Read 1919 times.
LFE
Tube Pre Amp
« on: 20 Oct 2006, 10:21 pm »
Hello!
I was looking to get some input on a tube Pre Amp. I am looking in the $3000 up to $6000 range. What is the best thing going in that range?
dado5
Re: Tube Pre Amp
« Reply #1 on: 20 Oct 2006, 11:15 pm »
Choice would have to include what you are using it for.  Do you need phono or just volume control/source selection? Do you need to boost the level of your sources (very unlikely nowadays)? Is you amp tubed or solid state?
Right off the bat I would say you are overshopping.  A tube pre-amp (excluding phono) is just a voltage gain stage usually connected to a low impedance output stage (90% of the time a cathode follower.) There is only so much that can be done with this configuration and not a lot of room to cut costs. Truth is a $600 unit may well sound better than a $6000 one.
If you want to 'flavor' a solid state system and don't need gain:
http://www.decware.com/linestage/zp1.htm
If you want gain with 'flavor':
http://hollowstate.netfirms.com/line2A.htm
About a 'cost-no-object' as I would go:
http://www.audionotekits.com/line.html  It's a kit but pay someone to put it together and you  are still below $2K with a circuit that has more engineering in it than the highest priced CJ.
If you need phono, I would go with the AN as well.
PhilNYC
Re: Tube Pre Amp
« Reply #2 on: 20 Oct 2006, 11:22 pm »
Hello!
What amp are you going to match it with?
Parnelli777
Re: Tube Pre Amp
« Reply #3 on: 21 Oct 2006, 04:12 am »
This  2 piece Wright Sound AU-1500 is just wonderful sounding, and at $2400, a relative bargain. In fact, the only pre that I've heard that sounded a little better is the Viva Linea 45, but it runs over $9000 with the outboard power supply. I have the Wright WLA12A, and it's a giant in its own right at $900.
George builds some really nice tube gear- and has been for more than  30 years now.
http://www.wright-sound.com/scripts/prodView.asp?idproduct=8
S Clark
  • Guest
Re: Tube Pre Amp
« Reply #4 on: 21 Oct 2006, 04:17 am »
The Dodd battery preamp is causing quite a stir.  It may take a while to get delivery, but it could well be just what you are looking for.
chadh
Re: Tube Pre Amp
« Reply #5 on: 21 Oct 2006, 04:51 am »
tberd
Re: Tube Pre Amp
« Reply #6 on: 21 Oct 2006, 11:47 am »
 If you want solid state sound , I can't help you . If you want tube MUSIC then look below .
 This unit just blew away a Halcro DM10 at 15+ times the price .
 MeiXing MC-2A3 Valve tube Pre Amplifier . $943.00 plus shipping .
 http://www.nysound.com/exec/servlet/CategoryServlet?action=productdetail&itemID=mex-2033-01027&formID=0
tberd
