400GB Hard drive for $99 free shipping!
0 Members and 3 Guests are viewing this topic. Read 7811 times.
95bcwh
« on: 15 Oct 2006, 03:21 am »
Lowest price I can find on the web!
http://shop4.outpost.com/product/4799749
..just buy yourself an external case then you're all set :thumb:
mjosef
Re: 400GB Hard drive for $99 free shipping!
« Reply #1 on: 15 Oct 2006, 05:48 am »
They have had that deal running for several weeks now, certainly the best deal on that size anywhere...I got 3 of them for my future PC based media center.
rajacat
  • Washington State
« Reply #2 on: 15 Oct 2006, 07:19 am »
Any recommendations for a good case?
Raja
John Casler
« Reply #3 on: 15 Oct 2006, 04:07 pm »
Looks like that "special" is over, but now they have this MAXTOR for $79.
http://shop4.outpost.com/product/4116853
Only 300G though
kenscott30
« Reply #4 on: 15 Oct 2006, 04:22 pm »
I love this case, use it with my MacBook Pro.  No internal cables.  Very nice quality.
http://www.firmtek.com/seritek/seritek-2en2/
Ken
95bcwh
« Reply #5 on: 15 Oct 2006, 04:51 pm »
But that's too expensive man!!
I use an external case made by NEC.. only $31 shipped!
http://www.dealsonic.com/neon5sinecch.html
Ken
rajacat
  • Washington State
« Reply #6 on: 15 Oct 2006, 06:45 pm »
That case is more what I'm looking for. I like it to be quite and have a low key pilot light. Does the NEC meet those criteria?
Raja
[/quote]
duff138
« Reply #7 on: 15 Oct 2006, 07:42 pm »
is it possible to put any internal drive in an enclosure like that?
95bcwh
« Reply #8 on: 15 Oct 2006, 08:33 pm »
That case is pretty versatile, if can put any internal drive 3.5" in it, read the details specs just for sure.
Paul_Bui
  • Rode NTK and S-1 microphones
« Reply #9 on: 16 Oct 2006, 06:49 pm »
Thank you 95bcwh and John.  I missed the 400GB deal but was able to get a 300GB and a NEC case.  I would like to get at least two of the 300GB at that price, but they put a limit on it.  Anyway, this will help me last a bit longer.  Right now, there are only 60GB left on each of two 300GB HDs I have.
byteme
« Reply #10 on: 17 Oct 2006, 02:36 pm »
It's back, but this time it's only $89 shipped!!
http://www.outpost.com/product/4596287
WOW!  Got a Coolmax case from amazon for $24.99 shipped free when I added a CD so I'm all set.  $.2875/GB is about the best deal I've found.
Carlman
« Reply #11 on: 17 Oct 2006, 02:59 pm »
Wow, good find!
If you buy 4 and hook it up to something like this: http://www.2cooltek.com/product.php?productid=971
You'll have a nice little 1.6T NAS for under a grand... which is a very good deal. :)
-C
zybar
« Reply #12 on: 17 Oct 2006, 03:05 pm »
Too bad my pc only has SATA interface.
George
95bcwh
« Reply #13 on: 17 Oct 2006, 03:13 pm »
I  don't understand why this kind of casing cost so much..it's just a bunch of plastic with some wiring..why cost >$400.. :scratch:
Wow, good find!
-C
95bcwh
« Reply #14 on: 17 Oct 2006, 03:14 pm »
George
George,
  Just buy an external case and hook it up to your PC using USB.. :thumb:
95bcwh
« Reply #15 on: 17 Oct 2006, 03:17 pm »
F-100, do you know where I can find a server case for cheap?
George
You can use it as USB external drive. :)
Carlman
« Reply #16 on: 17 Oct 2006, 03:29 pm »
 :oops:  Didn't see that the drive was IDE... Nevermind about that SATA NAS enclosure.
Barry... Any purpose-built specialized piece of gear will cost more than other non-standard multi-use devices.  You can always build your own and save all that money.... and instead spend your time making it work the way you want... like anything else, really..
byteme
« Reply #17 on: 17 Oct 2006, 03:33 pm »
George
www.techbargains.com
http://dealnews.com/dealpc/
http://dealmac.com/
Here is where I go for all my PC related shopping - and where I found the $90 400gb drive.
F-100
« Reply #18 on: 17 Oct 2006, 03:39 pm »
RAID storage systems are not cheap. :)
If you want cheap solution, then go with USB external case but there is a limitation.
95bcwh
« Reply #19 on: 17 Oct 2006, 03:46 pm »
What about this one?
http://www.supergooddeal.com/ProductDetails.asp?ProductCode=MB455SPF&Click=16749
