0 Members and 3 Guests are viewing this topic. Read 7810 times.
Too bad my pc only has SATA interface.George
You're money ahead doing 2 - 400 gig external drives vs. a single 750 gig drive. I have a 200 gb drive I bought about 3 years ago that was more expensive than the 400 gb version I just bought with this smokin' deal.
I was just doing cocktail-napkin-math. If an "average" length CD is about 450 MB (hard to say- I have older CDs that are 35 minutes and newer ones that push 78 minutes), then it would 'FLAC' down to about 225, right? I was trying to err on the side of having extra room, especially since I don't plan to quit buying new stuff!
I have a couple of 250 gb drives linked in my desktop. I have about 300 albums of .flac files and the total now is a little less than 200 gigs. However Dell configured the simple RAID between the two, it's invisible to the SB.Your math is reasonable. I hadn't thought about the 'one drive' streaming issue, as capacity hasn't been a thought in my streaming context. I was thinking more about .wav backups, which actually has been a consideration for me in the past.Even if you manage to fill up a 400 gb drive with .flac files, this will take a long time if you're burning the discs yourself. You'll have time to think about the next step.
I thought the problem was that the SB won't recognize it unless the file is all in one folder, hence all on one drive? Obviously it would be a lot cheaper to go with a couple of 400 GB drives (which I have, actually).
