0 Members and 1 Guest are viewing this topic. Read 8943 times.
Phil,> I am getting the best sound; great balance, no noticeable bumps/dips, no resonances, detail in gobs, soundstage, imaging, etc. <I have a simple explanation. If you now have first reflections under control that reduces greatly distance-related comb filtering effects. So now when you move your head half an inch the frequency response remains much more stable. I recently wrote an article about this, and mentioned it in another thread in a different section at AC, but I believe it applies here as well:www.ethanwiner.com/believe.html--Ethan
...But right now, I'm pretty much getting the best sound I've *ever* gotten, and for the life of me, I'm having trouble hearing differences between gear I could easily hear differences 3 days ago...
The alternative explanation is that the differences in the electronics are actually quite small - especially compared to those of the speakers, the room, and the speaker/room interaction. If you got the room nailed down, everything else is small beer.Ethan: could you expand on the differences between the Real Traps, GIK, ReadyTraps, and other commercially available traps that are all based on essentially the same materials?Thanks,Jim
Okay, I know I need to treat my little bedroom studio, so I went to eBay and bought the cheapest thing that claimed to be a bass trap.
Phil,> Am using GIK 244's <Why?Seriously, you might try hanging a large soft blanket or bath towel over them as a test, to see if that improves imaging even more. The canvas facing on those panels is too reflective IMO to do a great job as front wall treatment.Other than that it sounds like you're getting great results.--Ethan
