0 Members and 1 Guest are viewing this topic. Read 21834 times.
Quote from: LightFire on 7 Oct 2006, 05:12 am........You don't need "purifiers". The power supply circuitry of your sound system already do it for you.No, they generally don't, at least not adequately. Your lack of empirical curiosity is appalling. Like Athena, your conclusions spring fully formed from your head. But sadly, you are no Zeus. Are you skirvis is disguise? If wishes were fishes......To everyone else -I heard a PS Audio Duet Power Center yesterday -http://www.psaudio.com/products/duet_power_center.aspIts $100 dollars off this month @$299. Its really quite impressive, and will run a whole system (though possibly not a 250wpc+ amp). The conditioners I build are (IMO) better, but if I sold them, they'd be more expensive.Take one home making sure you've a return privilege. If you don't hear an improvement, or feel the improvement isn't worth it, return it. Heck, you may have pristine mains power. Or you may have perfect components just like LightFire. But please, please, form your opinions by actually listening and evaluating, rather than pulling your conclusions out your arse.FWIW,Paul
Now if you are full of empirical BS like Occam you could go ahead, pull a bucket of money out your arse like he does and buy some audio cosmetics to see how cool they look.
If clean power is just a bunch of B.S., then can someone explain why the folks on the following list spend their money with Equi=Tech?
The only power "purifier" you will ever need is a surge protector power bar.
Do your research, use your brains. This is a good article to start:http://www.theaudiocritic.com/cwo/Sample_Articles/
Well, Equi=Tech isn't so much about "clean power" as they are about "balanced power" which in itself does nothing to clean up junk on the AC mains but rather addresses the problem of equipment chassis leakage currents on the AC safety ground lead.
.......Do your research, use your brains. This is a good article to start:http://www.theaudiocritic.com/cwo/Sample_Articles/
8. Conditioner LieJust about all that needs to be said on this subject has been said by Bryston intheir owner’s manuals:“All Bryston amplifiers contain high-quality, dedicated circuitry in the power supplies to reject RF, line spikes and other power-line problems. Bryston power amplifiers do not require specialized power line conditioners. Plug the amplifier directly into its own wall socket.”What they don’t say is that the same is true, more or less, of all well-designed amplifiers. They may not all be the Brystons’equal in regulation and PSRR, but if they are any good they can be plugged directly into a wall socket. If you can afford a fancy power conditioner you can also afford a well-designed amplifier, in which case you don’t need the fancy power conditioner. It will do absolutelynothing for you. (Please note that we aren’t talking about surge-protected power strips for computer equipment.
Folks hereabouts know that I build my own powerconditioners. As cumbersome and bulky as they may be, others who've built them also must be delusional as they seem to think they offer worthwhile improvements.
Quote from: LightFire on 9 Oct 2006, 06:25 pm.......Do your research, use your brains. This is a good article to start:http://www.theaudiocritic.com/cwo/Sample_Articles/It would be a good idea if the AudioCritic updated their twaddle -Quote8. Conditioner LieJust about all that needs to be said on this subject has been said by Bryston intheir owner’s manuals:“All Bryston amplifiers contain high-quality, dedicated circuitry in the power supplies to reject RF, line spikes and other power-line problems. Bryston power amplifiers do not require specialized power line conditioners. Plug the amplifier directly into its own wall socket.”What they don’t say is that the same is true, more or less, of all well-designed amplifiers. They may not all be the Brystons’equal in regulation and PSRR, but if they are any good they can be plugged directly into a wall socket. If you can afford a fancy power conditioner you can also afford a well-designed amplifier, in which case you don’t need the fancy power conditioner. It will do absolutelynothing for you. (Please note that we aren’t talking about surge-protected power strips for computer equipment.Sounds great save for the fact that Brystron has changed their position -http://www.bryston.ca/Bottom left, 'Torus Power Power Conditioner'and it might be that Bryston has cynically identified a market opportunity, or it may be that they actually listened......LightFire - You might ask Mr. Tanner on the Bryston board here on AudioCircle why he has foresaken your deeply held beliefs.Could you do us all a favor? Rather than regurgitate exactly what is in the AudioCritic, save your typing efforts and just give us the specific number of your well reasoned conclusions. Regards,Paul
You might actually look inside an Equitech product, and see the grounding lead for the shield between primary and secondary. Or the Corcom filters, or the capacitors.If you read Glasband's patents, there are about as many claims dealing with differential noise as the cancellation of reactive leakage currents.
And if you believe your ears, a simple switch on a balancing conditioner's secondary center tap will allow you to switch between isolated and technical power so that you can make your own assessment of how much benefit is provided by the balancing and how much from other noise attenuation.
Slugworth - I can certainly understand your missing the point that the main interest of many audiophiles is the efficacy of powerconditioning when mains power IS available, as it seems that someone, for unknown nefarious reasons, is stealing the subject from all your sentences.
Personally, the only use I have for AC power anymore is as a convenient means for charging batteries. se
Wiring:Just go with Signal Cable, Element Cable, or Blue Jean Cable stuff. These (by audiophile standards, very affordable brands) follow Jon Risch recipes (he moderates the Audio Asylum cable forum and is well respected). Would more expensive stuff sound different? (yes); better? (that's subjective to the ear and equipment involved). IMO until your system budget exceeds $10k the money is better spent elsewhere (if you're situation is like most, in the room itself).Conditioning:Site dependent. I've heard it make a difference (old light industrial neighborhood), but never where I've lived (50 year old suburb with horrible wiring, 20 year old suburb, new country house). A friend brought one to the 50 year old house and it barely made a difference to me, the money could be much better spent elsewhere. Borrow one or take one home on loan and try it. Before you buy search around here for ideas, there's several low cost options available.
I'm in the same boat as you, SE aa
