0 Members and 1 Guest are viewing this topic. Read 21608 times.
It was mentioned earlier, that RFI is in fact blocked by the equipment transformers, but the line run from power-cord input to transformer might still radiate RFI into the chassis/internals and cause problems, specifically, could cause op-amp oscillation. Is RFI the major culprit then, that conditioners aim to reduce? If so, why not just put a R/C, or a ferrite, on the line run in question, or even on the power cord, and eliminate the costly conditioner units?What are the noise frequencies that we are worrying about here (regarding op-amp oscillation risk, etc) - are they in the MHz ranges, or are they down in the kHz ranges?...
