0 Members and 1 Guest are viewing this topic. Read 5715 times.
What do you think of my computer guy's recommendations for the whole PC system?
XPS 200(System Identifier: EWR41B56) * XPS 200 Small Form Factor: Pentium D Processor 820 with Dual Core Technology (2.80GHz, 800FSB) * Genuine Windows XP Media Center 2005System Price : $499.00Operating SystemGenuine Windows XP Media Center 2005Memory1 GB DDR2 NON-ECC SDRAM 533MHz (2 DIMMs)Hard Disk Drive250 GB EIDE SATA II Hard Drive (7200 RPM)Video128MB Radeon X600Certified RefurbishedCertified RefurbishedBaseXPS 200 Small Form Factor: Pentium D Processor 820 with Dual Core Technology (2.80GHz, 800FSB)Media Bay8X DVD +/- RW w/dbl layer write capabilitySoftware UpgradeTrend Micro PC-cillin with AntiVirus and Spyware removal 15-monthsSound Blaster Audigy ADVANCED HD Audio Software EditionHardware UpgradeSingle TV Tuner with Remote ControlUSB Optical two button mouse SoftwareAdobe Acrobat 6.0 ReaderSonic CineplayerMusic Match 10.1 SoftwareISP Search AssistONLINE TRAININGImage Restore SoftwareWild Tangent Gaming ClientNet Zero ISPISP SoftwareMicrosoft Works 8.5Support SoftwareAOL ISP SoftwareAOL 8.0 ISP SoftwarePhoto Album 6.0 StarterAOL ISP SoftwareDell Direct DownloadService SoftwareOperating System CDRoxio Creator, My DVD LEDell 964 Printer DriverAOL 9.0 ISP SoftwareWindows Media PlayerAOL 9.0 ISP SoftwareMiscProcessor LabelLabelNo Floppy DriveAOL Software DocumentationShipping MaterialDell Enhanced Multimedia USB KeyboardDimension XPS 200
Hi Woodsyi:I have a computer in our loft(which opens to our family room where my audio gear resides). My wife uses this computer and I didn't want to start ripping CD's into that harddrive. Plus it is a little noisy when on. I thought that it would be better to have a separate PC in my music room just for running the SB3. I would like to spend as little as possible for this PC and I thought staying under $500 is reasonable. The external harddrive would have been used as a back-up to the internal seagate. rklein
You don't need a new PC. If you get a NAS that has barebone OS like Infrant ReadyNas that can add Slimserver on, you don't have to have your PC on. YOu can also back all of your PC on it since you will have over 750 GB usable space on a TB unit with Raid 5.
Quote from: woodsyiYou don't need a new PC. If you get a NAS that has barebone OS like Infrant ReadyNas that can add Slimserver on, you don't have to have your PC on. YOu can also back all of your PC on it since you will have over 750 GB usable space on a TB unit with Raid 5.Good point, although the one thing to be carefull of is noise. Most NAS units that I've seen don't have silent operation as their primary objective. Their hard drives tend not to be the quietest available.Of course, if you can put the NAS box in a closet somewhere, then you avoid the problem entirely. In that case, I'd also look at the Lime Technology unRAID.
Hard drives are not quiet and you really do want that fan running.
Do you have a backup in the event that your 400GB USB external hard drive fails?Raja
