0 Members and 1 Guest are viewing this topic. Read 5724 times.
Thanks everyone F-100, Icrim:I do have a very nice HP laptop that I use for powerpoint presentations. I bought it about one and a half years ago. It has wireless capabilities. I like your idea. However, I can't use the main computer as my storage device as it sits up in our loft which is open to the family room(music room) below...(you can definately hear the fans from the family room. I do have an older computer that I could stash somewhere else and connect an external harddrive to that. I also have an older Toshiba Tecra laptop that I might be able to connect an external harddrive to. I should be able to rig something up at a very minimal cost.Thanks,rklein
Let me get this right!!! So whenever you listen to music, the main computer must remain off to avoid the loud fan noise?? What if your wife is using that computer and you want to listen to music at the same time???
Does an external harddrive have the same noise issues we are discussing?Thanks,rklein
I recently set up a Synology Cubestation NAS with 4 Seagate Barracuda drives in Raid-5, and then loaded on a tweaked version of Slim Server developed by one of the tech mavens over on Slim Devices' forums.
BlueWax, How much cost for the setup above not including the hard drives?Thanks
The Cubestation CS-406 runs a little north of $600; the consumer version (denoted by CS-406e) is a little less but doesn't offer the same RAM. I picked the hard-drives up as an OEM special on Newegg.Not cheap, but in line with other NAS offerings. I was sold on the ease of use, speed, and availability of the tweaked Slim Server (SSODS). The other options bandied about on the 3rd Party Hardware forums at Slim Devices all seemed to have a significant drawback or quirk that turned me off. See: http://oinkzwurgl.org/software/ssods/
My question is why did you select Synology over Infrant when the cost is similar? Anything about Infrant I should know about?
Hi Bluewax & Woodsye:What about something like this. http://cgi.ebay.com/Thecus-N4100-2TB-NAS-Cheaper-than-Infrant-ReadyNAS-NV_W0QQitemZ200031124478QQihZ010QQcategoryZ64072QQssPageNameZWDVWQQrdZ1QQcmdZViewItemThanks,rklein
