0 Members and 1 Guest are viewing this topic. Read 600105 times.
Say,Thanks for your initial thoughts. I have a dual box mono that I am burning in. I'm at the 250hrs mark, however I will wait for the full 400hrs before being critical. It is good to get a blow by blow of the burn in process if you feel like posting this. Do you have the double Silver wire? I presume that this is a standard option now? I have plenty of body from top to bottom so I attribute a large part of that to the double wire option.I have had my TVC's on Tuneblocks from day 1 (Graphite with Tungsten Carbide bearing) and I haven't really tested how they affect the sound. Partly because I know they work very well and secondly the preamp is sounding very good even though only just over half way toward the 400hrs +. I will evaluate that after burn in. Another thing I want to look at is separating the boxes a bit further apart than I have at the moment to see if that has any effect. One thing you can only do with double box. Some mention that taking the top cover off improves the sound. Anyhow there are a few more things to evaluate once the unit is broken in. Finally if you have multiple inputs I suggest to uses shorting plugs in any vacant RCA sockets as the vacant inputs pick up a lot of noise in my system. Cheers
Search on-line for it... I have ordered some from Speaker City in California but i don't think it was in-stock, been waiting a few weeks now.If you can't get it local, consider a group buy. Its only $7 per sheet but shipping is $12, so it makes sense to buy a few sheets and share.
I can back-up Rollo's claim with the Black Hole Pad on the tranformers 100%. best TVC tweak i've done...
Whoever is the first to get one of the new Promithues DAC's should begin a thread about it. Maybe call it....."Promitheus DAC anyone?" Just a suggestion....... I am looking forward to hearing about it.
QuoteHey Guys, Well trip to Malaysia was delayed to 6/12 due to getting a passport. It sucks but I am still going. Nicholas invited me over for a listen. Should be fun. He will have his personal GM70 amp with"C" cores ready for a spin. He said the power supplies are 27"x 13" alone. Wow!. rolloWell I finally figured out how to do a quote on the forum, but this amp is really starting to vex me. Hmm lets see 27" x 13" for the power supply, OK that would make the jabberwalkie about Hmm? What the.........., how in ........, well lets see I must of calculated wrong, if the skyhook part is 37.7" the plutonium mixer-black hole deconstruct-er must be ah 98" by say.........?, Oh I was afraid of that, dam the bad luck!Yep, I gotta buy a different house first!
