0 Members and 1 Guest are viewing this topic. Read 4128 times.
Posted by: Frihed91 To get a good baseline, try to set up your system for near field listening at low to moderate volumes. By doing this, you will take the room out of the equation and, actually, your speakers will not sound any better when you get all your acoustic difficulties sorted out, but you can lay them louder and perhaps (only perhaps) get a wider and deeper soundstage (Don't confuse this with more channel separation. That's not sound stage).By listening in the near field you will hear the best or nearly the best from your speakers (at low to moderate volumes) and, when you compare this sound with what you hear ordinarily, this will tell you how your room and furniture are affecting the sound. If you hear this glare and sibilence in the near field, these are not room prblems, they are system problems. Near field listening helps to define what are system problems and what are room problems.
