0 Members and 1 Guest are viewing this topic. Read 14360 times.
You'll have to do a search, but the CHENEY WECOLATOR is the solution to all your listening height problems!!
Quote from: Brian Cheney on 26 Sep 2006, 09:48 pmOK, so what was the other stereo system you liked as much as Jim's RM30's?Note: the speakers in a large TV like Jim's act as antiphase passive radiators at bass frequencies, which is why you heard the LF improvement when the TV was moved.I am a bit confused. Are you saying the speakers that are built into a TV have an effect on the sound even when they are not on? Secondly, how big of a TV are we talking about for it to have this interaction?Thanks B
Hi Jim, nice set up! I have a question about your sofit bass traps. Could you give a description of them?Is the underside open or just the vertical side?What is in them?What size framing did you use?What covering did you use?Size?Thanks
Try this experiment: Listen intently to a favorite tune w/ no other speaker in the room. Simply bring one other un-shorted 2-way (or more-way) speaker system & site it anywhere in the room not directly in the primary listening arc. You won't believe the degradation in quality.
I have been experimenting with using the Haffler circut to add ambiance to my. RM-40s with a pair of 626s behind me but closer than the main speakers It definitely seems to broaden the sound stage however I am concerned about phase issues and time delay effects. Thoughts anyone?
Taking another to have two dedicated rooms will be a bit of a challenge.
Sigh! My wife allmost divorced me after 45 years when I took the second largest of our 12 rooms as a dedicated one for my sound and home theater. Taking another to have two dedicated rooms will be a bit of a challenge.
Hummm! My diliema stems from the fact that to get the kind of sound I will accept I have had to completely separate my music sound system from my home theater sound system. So I have two separate didicated systems in the same room. I sit at one end of the room facing my RM-40s when listening to music. About three feet behind me are two 626's which are the left and right speakers for home theater, two sub woofers and a L/C/R. The left and right surrounds are two more 626's behind the RM-40s. When I want to watch home theater, I move my chair to the other end of the room (between the RM-40s), face it the other way and turn on the other system. So how much do all these speakers which are turned off when I am listening to music degrade the sound and how does one resolve this (short of having TWO dedicated rooms)?
