0 Members and 1 Guest are viewing this topic. Read 4195 times.
My previous set up was 34" from back wall and about 23" from side wall. Using Cardas I set them up at 52" out and 32" from the side wall. Okay, what did I found out about this? Well, I did not take measurement but I think I got rid of that 100Hz suck out some what. True that the sound was cleaner. BUT! this throw off the balance of the sound of my system! The bass re enforcement was lower and overall system sound bright. I couldn't stand it!
Hey! John, good point. You are right about the brightness. But I did played with the sitting position from far to near. Did not work. Still doesn't sound right. Well, the system sound great in my previous apartment of which was smaller before I moved here at my current place. I did a mesurement just to see how is compare to what I'm hearing... of which is pretty good. Bryan, yup you are right. They are designed to have some reinforcment from the back wall/corner.... Well, I know becuse I built them myself. They are always been placed closer to the wall... well closer than most other type of speaker. This thread would not happended if I did not taken the measurement. But as a DIYer I can't help wonder about it. No don't get me worng I do not based everything on measurement alone. I always play it by ears first than use the measurement just for comparison. Well, overall the measurement ain't bad... pretty good for this type of speaker. I guess I could live with that 100hz suck out. It doesn't bother me. I'm sure I could come up with something to help that at bit. But, Man! if I could get rid of that 100Hz suck out than it would be near perfect... measurement wise. Anyway, thanks all for your comment. Good to know that I could always find help here at the AC Take care, Buddy
