0 Members and 1 Guest are viewing this topic. Read 2725 times.
All you can really do is give it a try in your system and see if you can hearthe difference. A good DAC will definitely give you the potential of more sound,however it's like anything in the chain. If you upgrade the DAC, then the transportcomes up short and it's another rabbit hole to chase down.If you are happy with your phones and amp, the next logical step is to upgradethe source.It's the same with the cables, however, that's the last thing I'd spend big doughon. I've reviewed a lot of cable from reasonable to really expensive and havefound the cables to be a thin layer of icing on the top. If you have a fantasticsystem, they will give you a bit more, but otherwise I've seen people spend a thousandbucks on a pair of interconnects, when they have a three hundred dollar phono cartridge!It's all about synergy. Again, give a few things a try and see what you hearand like.
