Anyone have Component Video out from HTPC to a CRT TV?
0 Members and 1 Guest are viewing this topic. Read 1691 times.
jqp
Since I don't see much about VIDEO for HTPCs, especially with a high-end CRT TV, thought I would post this link to the original topic
http://www.audiocircle.com/index.php?topic=30597.0
jermmd
Re: Anyone have Component Video out from HTPC to a CRT TV?
« Reply #1 on: 19 Aug 2006, 02:14 am »
I used to before I went front projector. It's very easy using an ATI video card, the latest catalyst driver and the ATI dongle for HDMI to component. It's great using the computer on the TV, You won't need your DVD player, gaming rig, or CD transport after you figure it all.
jqp
« Reply #2 on: 19 Aug 2006, 02:37 am »
I see this new card:
All-In-Wonder 2006 Edition Radeon 256MB DDR3/PCI-E/VIVO/DVI
There is also the X1900 (the one above is the X1300)
It uses the PCI-E slot, but not sure if that improves performance for using an HDTV as a PC monitor.
I am thinking that component video is basically a step up from S-Video, but that it is still basically S-Video.
The manual shows the dongle and breakout box.
It also says for S-Video the max resolution is 1024x768.
OK I see that the catalyst driver is the  ATI driver
« Last Edit: 19 Aug 2006, 03:10 am by jqp »
jermmd
« Reply #3 on: 19 Aug 2006, 11:45 am »
You definitely want to use component if that's an option. I never used the All in Wonder cards but they should definitely work. Anandtech Hot Deals always has some deals on video cards if you're interested. You may want to check out AVS Forum Home Theater Computer section as well.
