What is the current state of PC to TV? (RGB out to TV)
0 Members and 1 Guest are viewing this topic. Read 1466 times.
jqp
Are there any reasonably priced solutions that do very good PC out to my Sony TV that has component and DVI interfaces?
For example, If I want to play a video in a media player on my PC but pipe the video to my TV, what do I want to do?
Or if I want to put my spreadsheet on the 40" screen of my TV, what do I want to do?
New video cards have HDMI output so this looks like a hopeful path.
I am not talking about watching a DVD from my PC on my TV screen (I would just use my DVD player), I am talking about the RGB output that normally goes to any PC monitor appearing on my TV screen.
Tr3vWh0r3
Re: What is the current state of PC to TV? (RGB out to TV)
« Reply #1 on: 19 Aug 2006, 12:50 am »
I have an LCD TV with an HDMI input. I have a video card with a DVI output. I bought a cable that is DVI > HDMI. I get a crystal clear picture 1:1. No overscan at all. I am using the 1280x720 output resolution on the video card and the LCD TV picks it up as such. Find the native resolution of your television and send that resolution through a digital HDMI/DVI signal and you should be ok.
jqp
« Reply #2 on: 19 Aug 2006, 01:49 am »
That works great if you are using an LCD computer monitor with a built-in TV tuner as a TV! Your LCD TV probably has a max resolution of 1366x768 which is fine for HDTV but actually limiting for the higher end PC video cards.
I have a Sony FD Trinitron WEGA 40XBR800 40" CRT so I need some massaging specifically for an HDTV-ready CRT TV. Since the manual says "the DVI-HDTV input terminal is compliant with the EIA-861 standard and is not intended for use with personal computers" I am not sure exactly what can be done. I seems to do 1080i and 720p.
Without experimenting with a $300 video card such as the newer ATI All-in-Wonder I am not sure what the component video out on the cards can actually do with this type of TV.
I have sent S-Video into the TV from a dell laptop with an NVidia card with mediocre results. Movie clips such as .avi and .mpg are acceptable because they are moving pictures. But definitely not uup to par.
I will have to research it online, but hoping someone has experimented with this setup. I would think that many projectors would have the same issues...
