B60 remote codes
0 Members and 1 Guest are viewing this topic. Read 1207 times.
julian
B60 remote codes
« on: 18 Aug 2006, 03:26 pm »
I have a newish B60R but without a remote control. Would an old remote unit of any age (i.e. one paired with an old B60R) be compatible, or would I have to buy a new one? Or to put it another way, have the IR codes and functions remained the same right from the first model B60R?
Regards Julian
  • The Demo is Everything!
    • http://www.bryston.com
Re: B60 remote codes
« Reply #1 on: 18 Aug 2006, 04:32 pm »
Regards Julian
Hi Julian,
Yes the old B60 remote will work.
james
