Put a sock on it?
0 Members and 1 Guest are viewing this topic. Read 2197 times.
OTL
Put a sock on it?
« on: 16 Aug 2006, 02:19 am »
Hey B!  My piano black RM30's w/CDWG's look great except for those shiny bolts and nuts on the Neo panels showing through the CDWG's opening.  Any thought ever been given to a stretchy sock-like thing?  Kinda like a cat suit for my not-so-beautiful, not quite hand-rubbed waveguides.
FWIW, the RM30's in piano black do have quite a large presence.  A soft, silky look on the waveguides would certainly soften they're overall presence in my living room.
Brian Cheney
    • http://www.vmpsaudio.com
Re: Put a sock on it?
« Reply #1 on: 16 Aug 2006, 03:16 am »
Try blacking out the PCB and screws with Magic Marker or similar, it really helps the look.
OTL
« Reply #2 on: 16 Aug 2006, 03:23 am »
Can this be done with the amps on?
Brian Cheney
« Reply #3 on: 16 Aug 2006, 03:29 am »
Yes.
OTL
« Reply #4 on: 16 Aug 2006, 03:36 am »
Got my Sharpie in hand.........
Thanks.   :D
john1970
« Reply #5 on: 19 Aug 2006, 08:56 pm »
To cover the screws you could also use a thin piece of black plastic (cut to fit) or black construction paper.
Just my ideas,
John
« Last Edit: 19 Aug 2006, 09:08 pm by john1970 »
Brian Cheney
« Reply #6 on: 19 Aug 2006, 09:05 pm »
We're starting to paint the screws and PCB with black epoxy, which covers everything and anchors the fasteners in place.
john1970
Black Epoxy paint??
« Reply #7 on: 19 Aug 2006, 09:14 pm »
Brian,
The black epoxy paint is an interesting idea.  Is the painting done by hand.  If so, can you please supply me with the manufacturer of the black epoxy paint so I can do this in field.
Thank you,
John
Brian Cheney
« Reply #8 on: 19 Aug 2006, 09:22 pm »
It's not paint, but glue.  You should be able to find it at hardware stores.
warnerwh
« Reply #9 on: 21 Aug 2006, 06:48 am »
Are you sure none of these black colored epoxies are not conductive?
