Stereophile SP2 Review
0 Members and 1 Guest are viewing this topic. Read 11678 times.
  • The Demo is Everything!
    • http://www.bryston.com
« on: 11 Aug 2006, 04:57 pm »
Hi All,
Check out the September issue of Stereophile for a complete review on the SP2 (pg 49) and comments on the KEF/BRYSTON/TORUS room at the recent Stereophile SHow in Los Angeles.
james
alpsy
Re: Stereophile SP2 Review
« Reply #1 on: 16 Aug 2006, 11:09 am »
hi james,
is that error in the review where is says that the sp2 has bp26 running gear?
cheers,
julie
MOZ
« Reply #2 on: 16 Aug 2006, 11:35 am »
I Julie,
What does the article says (not having stereophile here) ?
How do they compare the SP2 toward other pre ?
alpsy
« Reply #3 on: 16 Aug 2006, 12:03 pm »
Hi Moz,
They don't compare it with other pre's but in a nutshell they loved it, saying thats its 2ch performance is excellent as it's HT performance :)
Julie
« Reply #4 on: 16 Aug 2006, 12:05 pm »
hi james,
cheers,
julie
Not a mistake - the SP2 and the BP26 have identical analog gain stages.
james
« Reply #5 on: 16 Aug 2006, 12:11 pm »
I Julie,
The nice thing about the SP2 review in Stereophile was they really understood this is a State of the Art AUDIO product.
james
MOZ
« Reply #6 on: 16 Aug 2006, 12:18 pm »
I wish i could say the same with mine, but you still have it...
 :scratch:
alpsy
« Reply #7 on: 16 Aug 2006, 12:19 pm »
hi james,
cheers,
julie
james
which is different to the BP25?
thanks again james
julie
« Reply #8 on: 16 Aug 2006, 12:20 pm »
 :scratch:
Hi MOZ,
I will try and find out today for what is up with your SP2.
james
« Reply #9 on: 16 Aug 2006, 12:21 pm »
I Julie,
james
Here is the link to the review on our website
http://www.bryston.ca/pdfs/SP2STEREOPHILE.pdf
james
MOZ
« Reply #10 on: 16 Aug 2006, 12:22 pm »
That would be nice, James, 4 months... it starts to be a long time awaiting !!!
« Reply #11 on: 16 Aug 2006, 12:25 pm »
hi james,
cheers,
julie
james
thanks again james
julie
The BP25 does not have the MPS-2 power supply.
james
Jason Nugent
« Reply #12 on: 16 Aug 2006, 04:02 pm »
James,
In the review, they claim that the alphanumeric display turns off after any control operation and that the LEDs are the only visual clues.  Mine doesn't turn off - it just dims down to a lower level.  Did Stereophile audition a different version of the SP2?
« Reply #13 on: 16 Aug 2006, 06:36 pm »
James,
Hi,
Yes the latest version of software justs dims.
james
alpsy
« Reply #14 on: 16 Aug 2006, 09:35 pm »
Hi James,
Let me start again ...
The article says that the SP2 "is fully equivalent in features and performance to their BP26 preamp".
I found this surprising because the SP2 came out sometime before the BP26 and always thought and sure that I have read that it has the BP25 preamp section. Thus, the reason for me asking if this was a typo?
Apologies if I caused any confusion in your previous response to my question.
Julie
« Reply #15 on: 16 Aug 2006, 10:19 pm »
Hi James,
Julie
Hi Julie,
OK - let's be clear - the discrete Bryston Class A circuits are common to ALL our preamps and processors and have been for a number of years.
So performance is identical - features vary depending on which product.
Hope this helps.
james
alpsy
« Reply #16 on: 16 Aug 2006, 10:46 pm »
Roger that! :)
Thanks James
Julie
sberaha
« Reply #17 on: 17 Aug 2006, 04:35 am »
James,
I don't mean to belabor this issue, but just so I understand, isn't it true that the BP-26 has better performance than the BP-25 or the SP-2, despite having the same pre-amp circuitry, due to the MPS-2 power supply?  I ask mainly because I have a BP-25, and have been thinking about upgrading to the MPS-2, as I understand the performance improvement is notable.  Is the SP-2 power supply equal in quality to the MPS-2, in terms of driving the pre-amp circuitry?
Stuart
sikoniko
« Reply #18 on: 17 Aug 2006, 11:38 am »
I believe last night I had a similar issue to what Kal said he had happen. I was watching Sahara (HDDVD) on the 5.1 analog ports and every few minutes it would switch from analog to digital and I would hear what was coming through on my TV input. how do I set it to lock on the analog 5.1 when I am watching that source?
also, bad news. I did the FW update last night and I still get popping when changing channels on cable TV. it isn't as loud as it was, but definately still happens.
« Reply #19 on: 17 Aug 2006, 11:48 am »
James,
Stuart
Hi Stuart,
Correct the MPS-2 used with the BP25 would be better than the older power supply used with the BP25.
james
