Recomenditions for New Speakers
0 Members and 1 Guest are viewing this topic. Read 9943 times.
Antman27
Re: Recomenditions for New Speakers
« Reply #40 on: 9 Aug 2006, 01:59 pm »
Looks great But HOW do I do it ?
« Reply #41 on: 9 Aug 2006, 02:21 pm »
get a pic on your computer.
go to gallery from the top menu row.  click upload a pic and enter the file of the pic.  this should give you a gallery with pics hosted by AC.
Then start a reply and click the picture icon above the smilieys. Go to the properties of the pic on AC and copy its location between the img /img brackets created from clicking the pic icon.
Does this make sence?
Antman27
« Reply #42 on: 9 Aug 2006, 02:26 pm »
Got  it Thanks I did not know it hade to be in the galllery first
All makes sence
Antman27
« Reply #43 on: 9 Aug 2006, 04:46 pm »
Ok here it is the room is 25 X 14 and devided in 2 rooms Livingroom /HT and dining room
The AV is set up on the short wall so its 14Ft & I sit about 9.5 from screen & speakers
Let me know your thoughts ~
« Last Edit: 9 Aug 2006, 04:52 pm by MaxCast »
bgewaudio
« Reply #44 on: 9 Aug 2006, 04:48 pm »
couldn't get that pic?
Antman27
« Reply #45 on: 9 Aug 2006, 04:50 pm »
Antman27
« Reply #46 on: 9 Aug 2006, 04:54 pm »
NO idea what I am doing wrong I have the pix uploaded to my gallery -
Does this work
http://www.audiocircle.com/index.php?action=gallery;area=browse;album=795
bgewaudio
« Reply #47 on: 9 Aug 2006, 04:56 pm »
there it is, front on
bgewaudio
« Reply #48 on: 9 Aug 2006, 05:00 pm »
So along the back wall (which is this), does it open up to left or right?
« Reply #49 on: 9 Aug 2006, 05:01 pm »
looks like it is on the long wall, at one end.
looks like you have the room for a bigger sub as long as you lose the ladder.
Have you checked out the links I and others recommended?  They have 30 day return polcies...how can you go wrong?
Any FR measurements taken yet?
Antman27
« Reply #50 on: 9 Aug 2006, 05:03 pm »
Antman27
« Reply #51 on: 9 Aug 2006, 05:10 pm »
bgewaudio
« Reply #52 on: 9 Aug 2006, 05:12 pm »
Probably have a good 4 sq ft in that corner eh..............it's enough room!
Only thing is your probably going to lose a lot of LF into the dinning room.
bgewaudio
« Reply #53 on: 9 Aug 2006, 05:16 pm »
I'm looking very hard at the back right corner, this could be another option for placement?
You're right though, it's very congested in there!
Antman27
« Reply #54 on: 9 Aug 2006, 05:21 pm »
Dont need the LF in the dinning room -JUst the livingroom ~
I still have not hade a chance to run any test tones
I did play with the XO Feq
I set the sub to 150 & set the denon to 80 and the speakers to small & there was an improvement
I also tried the speakers to large and the XO on the sub at about 60 ,but seams like more lows with it set first way
I also can have the Denon fun LFE only Or LFE and main
bgewaudio
« Reply #55 on: 9 Aug 2006, 05:35 pm »
Is there enough LF now, or do you want more?
Antman27
« Reply #56 on: 9 Aug 2006, 05:41 pm »
I want MORE & trying  to opmitize this sub untill I get funds for a new one
I just checked my sub is 10" wide & I could go almost 15 " wide & would not have to move the wifes Dcore (ladder to no~place)
More pix with room restored with grils on & daughters toys YIKES I need a larger home.
Frihed91
« Reply #57 on: 9 Aug 2006, 06:11 pm »
This may not be very helpful, but in  room like that, I'd get some Ikea stands for my speaker (You can see them under my name in the picture) and push everything against the walls.  When you want to listen to music pull them out 3 feet toward the black soffa and listen in the near field.  That's what I do with a narrow room.  It's just one option.
Oh, your dog brings back such ahppy memories of the goldens i owned when i lived in the states.  Now, in Copnehagen, i have not that much room and I have a little dansk-svensk gaardhund named Rene.
How did you get the pictures to download.
bgewaudio
« Reply #58 on: 9 Aug 2006, 06:36 pm »
Did you say you tried loading the sub in that right hand corner?
bgewaudio
« Reply #59 on: 9 Aug 2006, 07:03 pm »
The reason I keep stressing that back corner is because low frequencies are augmented by boundary proximity, and then begins to escalate into a series of dips (which you may be sitting in now) and peaks.
Seeing how there is a boundary in that corner this may augment the bass in the way you want it to.  If you have enough Leeds, why not, doesn't hurt to try, I would imagine you're desperate enough to try anything now?  :lol:
