Thanks Bob , I will give that a shot -should I also run the Line Level Input wide open to its loudest ?
I think I tried this when I set up the denon a while back and it set the individual speaker volume like this
R +10
C +12
L + 10
RS +12
Ls +10
SUB - 6
In a denon forum fokes said it would be better to be closer to 0
so IE
R 0
C +2
L 0
Rs +2
Ls 0
SUB 0
The problem with large signal boosts is over driving the speakers. Typically, the receiver will not have a problem. In general, cutting is safer than boosting. So, yes, being close to zero or negative is preferable.
What you see with the sub's level maxed is that the receiver had to attenuate it by -6 and still had to raise the other channels to reach a level balance. So, as suggested, reduce the sub's level until you get the other channels near zero.
An obvious question... Is the sub tight into a corner? If not, you're losing quite a bit of free boundary boost.
Regarding the SPL meter... I think you can find compensation values for the RS analog meter on the net since it is not linear. Some test CDs, like the one from Rives has the compensation values taken into account in the test tones. I read recently in Stereophile, I think, that RS sold the rights to the analog meter to another company and they have improved the meter.
