0 Members and 1 Guest are viewing this topic. Read 7893 times.
gongos: How do you control volume?
Quote from: kfr01 on 11 Jul 2006, 08:29 pmgongos: How do you control volume?I use my PC as a source so I can control the volume with foobar.
Quote from: gongos on 11 Jul 2006, 11:46 pmQuote from: kfr01 on 11 Jul 2006, 08:29 pmgongos: How do you control volume?I use my PC as a source so I can control the volume with foobar.Then, by definition - aren't you using a preamp?
gongos: Doesn't that sort of volume control (on computer, prior to DAC) result in lost resolution and less than a bit-perfect stream being sent to the DAC? I'm almost positive it does. Here's a post by Steve of Empirical Audio:http://db.audioasylum.com/cgi/m.mpl?forum=pcaudio&n=2520&highlight=digital+volume+control&r=&session=Please correct me if I am wrong. Edit: There actually seems to be a split on audioasylum regarding whether this lost resolution matters much when upsampling to 24 bits prior to volume control... Steve? Anyone?
Quote from: kfr01 on 12 Jul 2006, 04:05 amgongos: Doesn't that sort of volume control (on computer, prior to DAC) result in lost resolution and less than a bit-perfect stream being sent to the DAC? I'm almost positive it does. Here's a post by Steve of Empirical Audio:http://db.audioasylum.com/cgi/m.mpl?forum=pcaudio&n=2520&highlight=digital+volume+control&r=&session=Please correct me if I am wrong. Edit: There actually seems to be a split on audioasylum regarding whether this lost resolution matters much when upsampling to 24 bits prior to volume control... Steve? Anyone? If that's the case, I wouldn't call it a preamp.
Quote from: gongos on 12 Jul 2006, 11:46 amQuote from: kfr01 on 12 Jul 2006, 04:05 amgongos: Doesn't that sort of volume control (on computer, prior to DAC) result in lost resolution and less than a bit-perfect stream being sent to the DAC? I'm almost positive it does. Here's a post by Steve of Empirical Audio:http://db.audioasylum.com/cgi/m.mpl?forum=pcaudio&n=2520&highlight=digital+volume+control&r=&session=Please correct me if I am wrong. Edit: There actually seems to be a split on audioasylum regarding whether this lost resolution matters much when upsampling to 24 bits prior to volume control... Steve? Anyone? If that's the case, I wouldn't call it a preamp.Huh? Don't you feel like you are losing resolution by using the digital volume control of foobar?
No. Losing resolution compared to what?
Quote from: gongos on 12 Jul 2006, 11:47 pmNo. Losing resolution compared to what?Losing resolution compared to the bit-perfect stream from the CD. Did ya click the link I posted? Steve at Empirical Audio, from the aforementioned link:"You are losing resolution by doing digital volume control. An active analog volume control will retain the resolution. The effect will be most noticable as an improvement in high-frequency detail. A good preamp is needed however."You are doing digital volume control and are likely losing resolution (information!) prior to your DAC stage.
