Pat-5 Super-Fet
0 Members and 1 Guest are viewing this topic. Read 2459 times.
SCM
Pat-5 Super-Fet
« on: 21 Jun 2006, 12:26 pm »
Greetings,
My pre-amp drops the right channel now and then.  If I push the mono buttons in then I get sound from both sides just not in stereo.
Then if i fiddle with the selector knob it`ll come back on with a little scratchy static sound then it seems to lock in.
What can I use to clear this up and where inside ?
BTW...I sent this in to Jensens Stereo Shop in December 1982 !
Any mods currently available for this?.
I listen to vinyl and use cd`s for background only, so a good phono upgrade would possibly interest me.
avahifi
    • http://www.avahifi.com
Pat-5 Super-Fet
« Reply #1 on: 21 Jun 2006, 12:45 pm »
You probably have a dropout (dirty contacts) in one of the pushbutton switch contacts.
The suspects can be the Input-Tape switch, the EPL switch, or either of the Mono-Stereo switches.
The cure is to spray the switches from inside the chassis with a good contact cleaner (Caig Labs Deoxit D-5 recommended) and then cycle the switches 50 times or so each with the unit turned off.
Yes there is a major upgrade for your old Pat-5 chassis.  We still support it with our newest OmegaStar PAT-5 circuits.  This a complete new internal circuit set of our design, along with precision volume and balance controls.
The upgrade price is $599 and includes new phono, line, tone control, and power supply circuits, along with a new three year parts and labor warranty on everything we do. Any minor repairs will be done too at no extra cost.
This will provide you with with as nice a solid state preamplifer as they get, with outstanding functionality.
Frank Van Alstine
mark funk
Pat-5 Super-Fet
« Reply #2 on: 21 Jun 2006, 10:05 pm »
Hi Frank, Talking about Super Fet Pat 5s. I picked one up on ebay its a SL not a EC. Sounds OK but the selector switch is very hard to turn, would some contact cleaner help or is there something other I could try? Also looking at the circuit boards, they have Transcendence printed on them not Super Fet? What year would that be from? Thank  :smoke:
avahifi
Re: Pat-5 Super-Fet
« Reply #3 on: 24 Jun 2006, 05:29 pm »
Mark, give me a call at 651-330-9871 for help with that old Super Fet Pat-5.  Although that model in the Pat-5 chassis never had an "SL" name.
Frank
Zheeeem
Re: Pat-5 Super-Fet
« Reply #4 on: 24 Jun 2006, 10:47 pm »
Gosh.  I still have a Super FET PAT-5 in active use.  It's part of our HT, and is on about 8 hours a day.  Watta W-O-R-K-H-O-R-S-E!!!
I get some dropout once in a blue moon.  It's always the selector switch.
