0 Members and 1 Guest are viewing this topic. Read 11084 times.
Many rooms have this problem, and the solution - as I'm sure you know! - is bass traps as well as having good speaker and listener placement. The worst place to sit is halfway in the room front to ...
Barry,> What if you can afford to cover both your front and rear wall with bass traps. Does this rule still applies? <Absolutely! For the best results you want as much bass trapping as possible and you should place the speakers and listening position optimally.> if you cover the walls with bass trap, can floorstanding speakers be placed closer ( less than 3 ft ) to walls? <Speaker distance to walls is only one of several factors. But to answer your question, bass trapping ...
Ethan, About the rear(back) wall, i have a small window and bare wall. Can i use 2 or 3 2" thick panel and put flat against or spacing out 1 " from the wall to create a bass trap? I already have 4" bass trap on each corner of the room and i put it on floor against the wall and floor corner. Due to the WAF, i can't stack second trap on top of the first one. I don't know if i could lift the trap about 2 feet from floor will help more than laying it on floor.thanks.
