Possible to add a digital out?
0 Members and 1 Guest are viewing this topic. Read 1124 times.
BobC
« on: 31 May 2006, 02:07 am »
Hi Folks,
I have an old Rotel CD carousel RCD 940AX (I believe).  It does not have a digital out.  I was wondering if it is possible (worth the effort) to modify the unit giving it a good quality digital out and then use the unit as a transport to a DAC?
What do you think?  Would a carousel make a good transport?  Or should I sell it (probably only get $100 or so) and put my money toward a better transport?
Just that the thing still works great so I hate to let it go for little $$$.  Really only use it anymore for background music during parties...otherwise use Arcam DV78 for CD.
rbrb
« Reply #1 on: 2 Jun 2006, 02:46 pm »
It can be done but it costs $385 from here.....
http://www.msbtech.com/products/productsHome.php
I would say that it really is not cost effective.
BobC
« Reply #2 on: 2 Jun 2006, 02:58 pm »
Thanks for the info.  Yikes!   :o  $385 seems steep.  Agree that it's not cost justified with this player.
