0 Members and 1 Guest are viewing this topic. Read 9487 times.
How many watts would be dissipated at idle, roughly?
Very exciting!Any rough indications on price?And you mentioned show specials, any chance of extending these to the Audio Circle? - especially those who cant attend?
Any rough indications on price? And you mentioned show specials, any chance of extending these to the Audio Circle? - especially those who cant attend?
At the Los Angeles HE2006, we will be showing production prototypes of the new PLC•1 Remote Controlled Passive Preamplifier & D•400 400w Monoblocks. PLC•1 is the passive preamp you've all been waiting for...Features include 4 inputs (#4 input can be internally set as a HT bypass)Tape Loop, 2 pair of outputs, 12v trigger output, in a milled aluminum chassis with custom remote. Front panel controls as well as remote can control all functions and has both scroll up/down & direct access for all inputs. ...
How many amps will the D400 produce?
any pictures?
Dusty, aside from the move to the higher power Hypex amp module and presumably beefier power supply (larger toroid, more caps, etc.), does D400 share the same fundamental topology as the D200 and the updated D100, or have other changes been made? If there are topology updates to the D400, will they propogate back to the D100 and D200 amps?
