0 Members and 1 Guest are viewing this topic. Read 9485 times.
Any plans for a multichannel amp with the same specs?It would be great if you had a solution for ht or mc audio. Too many outlets needed for 7 monoblocks.
Our current plan is to make a chassis the width of two CIAudio monoblocks.... Our target price is $695.
From looking at the picture in the Stereophile blog entry, it doesn't appear that it turned out that way, but it could just be me trying to deduce too much from the picture.Does the final chassis size of the PLC•1 accommodate two D•100 monoblocks on top?Also, can you comment on why the PLC•1 ended up being $200 more than the projected cost?
How does the ALPS remote volume pot compare to your custom & ingeniously designed, beryllium wiper pot?
The ALPS potentiometer is also custom made for us.It has equal or better sound quality, and it's quieter with better tracking and feel.
How many pots did you have made this time--25 thousand?
The PLC-1 looks fabuous. Will this be purely a passive switch design or will it also contain a sizable transformer (TVC) to add some slight gain (6 db) and sound heft (ala Bent NOH, Music First)?
Purely passive, no transformers...I don't like coloration they add.
